Question about OKI C5510 MFP All-In-One Led Printer
Oki mfp c5510 flashing lights doesn't work
The 2 orange lights (page & exclamation mark) are flashing. The left green light is flashing slower. Printer doens't function.
  • 4 more comments
  • momo30 Oct 17, 2008
    No status monitor on my PC. Printer does not communicate with my PC. Thanks
  • Anonymous Jan 05, 2009
    after installing a new black toner this happened
  • Anonymous Feb 24, 2009
    After change the color drum and toner, i have the same problem.
  • pothole959 Mar 26, 2009
    Not quite the same, green light flashes slowly, orange question mark and toner lights flash quickly. Happened after black toner was changed.
  • Craig Gillette
    Craig Gillette May 12, 2009
    toner and alarm lights flashing, green light flashing slower, mfc display says no data from printer4.
  • Igor Studennikoff
    Igor Studennikoff May 11, 2010
    what error indicates on status monitor on your PC?
4 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: how to reset toner drum for the oki c5510 mfp?
. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 16, 2009
komguy
  • 2306 Answers
SOURCE: Reset the Drums on Okidata C5510 MFP Printer
Yes, you have to install a fuse in each drum unit, it's a littelfuse # 251-062. You can use google to find the procedure.
Posted on Jul 03, 2009
  • 44 Answers
SOURCE: I´ve got a message on my oki C5510 mfp
Check the toners are not empty. The printer only estimates how much it thinks should be left, there is a possibilty one is empty. this is best done by removing each toner in turn and checking that the hopper in the drum is full to level with the sponge surrounding it. Next check are the toner sensors. These are small and located to the right of each toner cartridge in the wall of the printer, one could be dirty creating the error and not allowing the printer to start up completely, causing the scanner connection to fail and giving you "Failed to get printer information". On this model the scanner and printer are essentially separate units joined by a USB cable.
Posted on Nov 08, 2009
Oki C5510 'Unable to detect printer'
If you have all the led's lit and they are not flashing it means the printer is in download mode. In other words its waiting for you to download new firmware. Look at OKI's site and find the firmware and follow the instructions. That's why you cant install drivers because the printer no longer knows what it is!
Jun 17, 2017 | OKI C5510 MFP All-In-One Led Printer
How do I fix parameter or argument error
In addition to ensuring that the mail server is set to relay email for the OKI MFP, you also need to go to the Send Mail configuration page and ensure that a From address is set (even if you have already inserted a default from address in the Mail Server configuration page).
Dec 30, 2009 | OKI C5510 MFP All-In-One Led Printer
Is there a Windows 7 driver for a OKI C5510 MFP?
No not as yet i think there still having problems with vista drivers.
Nov 23, 2009 | OKI C5510 MFP All-In-One Led Printer
I´ve got a message on my oki C5510 mfp printer "Failed to get printer information - Check printer". I´ve checked all cables and everything is ok. The toner light and exclamation light staying lit...
Nov 08, 2009 | OKI C5510 MFP All-In-One Led Printer
Computer cannot see Oki c5510 in network.
It's very possible that with a reboot of the printer and/or your router that DHCP assined a new IP address to the machine. Look in your router settings for the active clients and look for the IP address of the printer. Than go into your printer management within Windows, check the IP address assigned to the printer and change it to match the IP address you found on the router. It's happened to me before and it can be very frustrating.
Aug 08, 2009 | OKI C5510 MFP All-In-One Led Printer
OKI C5510 - when printing on photo paper, makes goo all over and photo does not print properly??
you must choose the thickest media type possible at the printer and on the pc. your fuser is not fusing properly causing toner to goo on the roller, changing to thick paper increases temp and slows printing to ensure bonding. some coated papers do not work well with OKI printers. you should check mnf website for specs and recommended papers types
Aug 04, 2009 | OKI C5510 MFP All-In-One Led Printer
Jul 03, 2009 | OKI C5510 MFP All-In-One Led Printer
How to reset toner drum for the oki c5510 mfp?
8. Restart printer.
Thanks, Joe
May 16, 2009 | OKI C5510 MFP All-In-One Led Printer
OKI C5510 MFP All-In-One Led Printer Logo
980 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
