Question about Frigidaire 24 in. GLD2162RDC Stainless Steel Built-in Dishwasher
Flashing Power Failure Light on Frigidaire Diswasher Model # FD989GFC2
I have a constant flashing "PF" light on my diswasher. I have reset the breaker several times and it just keeps flashing. Obviously the diswasher will not work in this mode. Any ideas?
Thanks,
Ron
rcurrent@printpack.com
  • 1 more comment
  • dguerra Nov 17, 2008
    flashing power failure. Will not complete the cycle. Problem is not the house breaker.
  • Anonymous Apr 09, 2009
    Same exact problem
  • yanickgagne Apr 15, 2009
    Same problem and nothing work
    Problem Solver:
  • 4 Answers
Check the grounding wire and also the neutral (white wire). you can have power into the unit and the netural be the problem. the circute can show power because electrical panels are grounded by the main cold water pipe that comes into your house. this means that ALL plumbing pipes can act as a ground. BE CAREFUL IF YOU HAVE AN " open ground or netural you can get eletricuted!!! best of luck
Posted on Dec 25, 2011
I have a Frigidaire that does the same thing. I was able to push the start cancel button then select a cycle and press the start button, shut the door and presto it worked.
Posted on Mar 16, 2009
Why do i have a problem with my Bosch diswasher mod:she9er55uc/51 ...sanitize and refil rince are flashing when i start the machine
The rinse light is telling you the resiviore is empty and should be refilled the sanitize means that option is choosen try resetting options
Jun 25, 2014 | Bosch 800 Plus Series SHE9ER55UC 24...
I have a frigidaire diswasher Model: FDB1100RHM (silver mist) have had it about a year. We just had to disconnect it to replace a drain (linked to my sink). After we hooke dit back up, when we plugged it...
Suggests a power failure. Check loose wiring at the junction box where power supply is connected. Check white and black wire connection to electronic control board. See if flipped switch in fuse box for line to dishwasher.
Just one possiblity. Others include burnt out heating element or bad pump. Time to check warranty for service call.
Oct 07, 2017 | Frigidaire PLD4555RFC Dishwasher
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Getting code PF, resetting breaker did not fix the problem. Dryer model Aeq6000es2.
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Help for my asko diswasher
try holding in the start button for 10 sec to see if it resets,or the board could be faulty part no 8801201
Apr 02, 2008 | Dishwashers
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
Open Questions:
Frigidaire 24 in. GLD2162RDC Stainless Steel Built-in Dishwasher Logo
1,174 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
