Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
PROBLEMS WITH WD DRIVE NOT SHOWING UP READ THIS
I have used this software and it worked. Paradox Partioning Magic http://www.download.com/Paragon-Partition-Manager/3000-2248_4-10070089.html Apparently the space on the WD was unformatted and unallocated, so it wasn't visible. After partitioning it, formatting it and allocating a drive letter, it workds like a charm.
  • vega89191 Oct 17, 2008
    sorry paradon not paradox
4 Suggested Answers
bluegreenash
  • 661 Answers
SOURCE: Trying to format a 500GB HDD at full capacity
sounds like the SATA - PATA converter doesn't accomodate for a 48 bit LBA (to handle disks of more than 137 GB)
you need to get the correct converter, as this one is not compatible, you should be able to return the converter as not fit for purpose (needs LBA 48bit).
Posted on Oct 11, 2007
Beni S-P
  • 1006 Answers
SOURCE: paragon partition manager
Yess it is:
Download this one and it will work 100%:
http://rapidshare.com/files/64053174/aiorecovery.rar
Rate this solution as FIXYA PLEASE
Posted on Nov 27, 2007
bob_computer
  • 3153 Answers
SOURCE: no writable WD smartware partition found
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
Bob
ExModerator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Posted on Dec 28, 2009
Paradox 7
It may be possible if you have a another lifetime. It might work in legacy mode, you can easily get a 3.5" drive to connect by usb, and image the disks using winimage then install from the images or even use the disks directly, but you are going to spend a LOT of time and effort and then it might not work. Move on unless your bitcoin collection is on the discs.BTW what is Window 85, did you mean Windows 95?
Jul 15, 2014 | Borland Paradox 7 Full Version for PC
Invalid parameter. File or directory does not exist. File: C:\PROGRAM FILES\HANDYCAFE\SERVER\PDOXUSRS.LCK Directory in use by earlier version of Paradox. File: C:\PROGRAM...
Invalid parameter.
File: C:\PROGRAM FILES\HANDYCAFE\SERVER\PARADOX.LCK.
go to the directory and change the file "PARADOX.LCK" to "PDOXUSRS.LCK"
Dec 12, 2013 | Ates Software HandyCafe
Can't read data on WD external my book hard drive
It seems that your WD hard drive is corrupted so
you are unable to access the stored files. But there is no need to worry since
it is very easy to recover data from corrupted WD partition by using Western digital partition recovery
software. Couple of days ago, even I was stuck under similar problem I tried
this software which really helped me to retrieve all my lost data.
All the best,
Linda William
Jan 01, 2013 | Western Digital My Book Essential 1TB...
Will paradox 8 run on a windows 7 os? home premium or professional? without any migration problems?
no
not unless you plan to use a virtual machine to emulate a earlier version of windows like 95 or 98
you could if your really determined
i hope this answers your question and please vote
Nov 30, 2010 | Corel Paradox 8
Read / write error
it is due to the write protect for your drive. If u have protected it by giving read and write protection try to disable them. it will work
Aug 24, 2009 | Kingston StorCase Remote Management...
WD HD Media player damaged my hard drive??
Hi Dear! This problem could be solved through a software. You should use Western Digital Disk Manager, your WD hard disk will work properly after using that your WD hard disk pass all test of the software. When it will pass all test it will work properly and in other condition if it will not pass then you should try again so that the software will fix the error and it will made workable.
Thank You
Jul 24, 2009 | Western Digital My Book Premium ES...
WD Scorpio Black 320GB SATA drive
Halarious, I had the same problem yet I used norton ghost. At least you still show 160 gb. Mine went all the way to 60 gb. Here is what I had to do to reclaim the lost. I downloaded something called "Magic Boot Disk" It gave me the whole 320 back yet have not found good cloning software yet. Magic Boot Disc is freeware avaliable at http://hddguru.com/content/en/software/2006.02.10-Magic-Boot-Disk/ Good luck cloning
Feb 21, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Can I Repartition WD 500GB My Book Firewire Drive w/DATA ON IT?
Greetings.
You will need to have a third party software to achieve this. I recommend norton partition magic. I have been using it in the same scenario as yours and works. they now support firewire. Easy to use and gets the job done.
Hope that helps.
Jan 10, 2009 | Western Digital My Book Essential Edition...
Formatting and Partioning WD My Book for Mac OS X
what are the tips of hard disk drive troubleshooting
Jan 08, 2009 | Computers & Internet
Computor does not recognise my book as connected have tried 2 different computors and a new computor to my book cable
I have used this software and it worked. Paragon Partioning Magic http://www.download.com/Paragon-Partition-Manager/3000-2248_4-10070089.html Apparently the space on the WD was unformatted and unallocated, so it wasn't visible. After partitioning it, formatting it and allocating a drive letter, it workds like a charm.
Oct 17, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
127 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
