Dell Inspiron 1501 Balck LCD Screen
I have a Dell 1501 that the LCD screen has gone black. I figure it’s the LCD screen backlight but when I try and connect it to an external monitor I still am unable to get it to display. The issue here is, because I need to change the display to the external monitor, but can’t because I can’t get he LCD to power up, am kinda stuck guessing if it’s the LCD or not? Any help would be great.
    President:
  • 1,257 Answers
You have to change the lcd and you can buy it online
Click on the link to know and buy lcd screen for your laptop http://www.lcds4less.com/
http://www.sparepartswarehouse.com/Laptop,LCD-Screens-Repair.aspx
http://www.laptoprepair.com/
Posted on Oct 17, 2008
Dell 1501 laptop screen has gone almost blank. When I open the laptop I momentarily get to see the screen as it should be. I have tried the 'fn' & 'up arrow' keys without success. Any...
This sounds like a loose wire on the backlight on the monitor.
If it were my computer, I would disassemble the screen and check the connections. You can find directions on Dell's site by going to support.dell.com and entering your service tag to get the downloads. You'll find the service manual there.
Jul 22, 2011 | Dell Inspiron 1501 Notebook
LCD Screen Repalcement
thats the screen problem u should change the screen than it gonna be alright,
Oct 10, 2009 | Dell Inspiron 1521 Laptop
New inverter in Dell Inspiron 1501 now the LCD screen gets hot!
I've had the same problem with a Dell Lattitude D531. I've been told that it's the screen itself (which may have led to the original inverter going bad) but that one should also check to make sure none of the screws are making contact with any wires back there.
Sep 10, 2009 | Dell InspironTM 1501 Notebook
My dell inspiron 1501 laptop has been flickeri ng colors or a lrge strip down middle , now half the screen is black with little color line
hello
This could be anything from the screen is dying or the inverter (electronic board that powers the screen' back light).
If you press slightly at the top of the screen, see if the lines will disappear or not, if it does then come back again; you might need to change your lcd.
hope it helped
TekSpotDotCoDotUK
Aug 26, 2009 | Dell Inspiron 1501 Notebook
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 20, 2009 | Dell InspironTM 1501 Notebook
My daughter's Dell Inspiron 1501 laptop screen has gone almost blank. When I open the laptop I momentarily get to see the screen as it should be. I have tried the 'fn' & 'up arrow' keys without success....
this sounds like a loose conection to the lcd inverter or the lcd cable to the motherboard. it can be repaired. how are you at taking things apart?
Feb 22, 2009 | Dell Inspiron 1501 Notebook
Dark Screen Inspiron 9100
If you replaced the inverter board and its still dark you need and new backlight itself http://cgi.ebay.com/LCD-Backlight-Lamp-for-Dell-Inspiron-9100-15-4-WXGA_W0QQitemZ150217509448QQcmdZViewItem
Dec 10, 2008 | Dell Inspiron 9100 Notebook
Monitor screen is extremely dark
It sounds like the backlight has gone out. You will need to replace the screen.
Jul 03, 2008 | Dell Inspiron 1501 Notebook
Dell notebook lcd scren
Make sure its not in hibernation,check brightness with darken and brighten buttons,does backlight work.Try hooking up external monitor and see if you get video.Other problems could be drivers.bad inverter card,LCD cable,LCD display,system board.
Mar 25, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
