Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor doesnt work
Gateway monitor model 900g stopped working. light was flashing blue last nite but this morning its not doing anything.cheap fix?
  • YANKEES9 Oct 17, 2008
    HOW DO YOU OPEN IT UP?
    Master:
  • 505 Answers
You can check the fuse on the monitor and replace it. In case the fuse is OK check the cable connector, display card on the motherboard.
Thanks
Posted on Oct 17, 2008
  • Indrajit Roy
    Indrajit Roy Oct 17, 2008
    First of all disconnect the power chord from the outlet. Turn the monitor upside down and place it on a soft cloth so that the screen faces down. You will see few screws on th eback which you need to remove. Then open the cover slowly. You will see a small fuse there
Gateway 19" lcd color monitor, product no. fpd1960 model no. 900g
The most common cause of power up issues with the Gateway FPD1960 monitor is a failure of the filter capacitors on the AIP-0100 power supply board in the unit. Here is a link to repair information for that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=206
Nov 14, 2012 | Computers & Internet
Monitor works intermittently
Hi Michael, it does sound like the monitor then. The most likely cause is bad capacitors in the power supply. Typically a cheap repair but you do have to solder and such. Unless you have to have a very expensive monitor its probably better to just replace it since basic monitors are so cheap these days. Good luck.
Feb 22, 2012 | Gateway FPD2185W 21 in. LCD Television
Gateway 900G does not stay on, has power
the_princes, On the rear side of LCD screen that you look at are two each long, straight, cold-cathode-fluorescent-tubes that need to "LIGHT-UP"and provide pure WHITE light to be reflected through the LCD glass panel that you look at from the front side! If you don't have any luck with Gateway providing warranty service or doing a swapout with them, then you should possibly look into having it Refurbished by someone locally in your area. I highly recommend that you go to youtube and watch some video clips of LCD MONITOR REPAIR to see exactly what you are getting involved with. When making a post to tthis site you should always give some "history" along with the trouble "symptom" such as how old is unit and approximate total amount of "ON" time the unit has. I hope you can use the info provided. I'm louie12fix on fixya or lmistyrel@aol.com Bye for now.
Oct 01, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
IC Power 19'' LCD Product PA192D Model # 900G quit working
I C Power PA192D Model 900G, Mfg Sep '05 19inch LCD
I purchased this monitor at Goodwill not working for $20. The 900G power light failed to come on and there was no video when turned on. To fix, first pull the 2 screws at the bottom of the back side of the monitor_ note this face is NOT removed by prying with a screwdriver like other monitors, it IS removed by sliding the face plate Upwards. Remove the LCD screws and remove the wires to the backlights carefully noting what goes where. Remove the metal cover and remove the 110volt power board. I found smoke trails under the cover and a swollen 470uf25v capacitor number C206, and replaced C110, C211 all were 470uf. Reassembled and found no change. Tore down again, used the ESR meter CapAnalyzer 88a and found C114 47uf25v to be 30% working, the volt ohm showed the cap to be good, that's why the ESR meter was needed. Replaced the 47uf25v C114, tested the large 100uf 450v capacitor, it tested only slightly under spec , could not find a 100uf at Radio Shack so did not replace it. So in this attempt the only thing changed was the 47uf C114. Reassembled and now works perfectly.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Nov 20, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Gateway 900g
I'm writing this using a recently repaired Gateway 900g. You may be correct about the power supply, as that was the problem on this unit. There was absolutely no response with this unit. No blue LED, no dim display. Nothing.
WARNING: BE SURE TO UNPLUG THE AC LINE CORD. THE POWER SUPPLY HAS DANGEROUS 120 VAC PRESENT IF LEFT PLUGGED IN. If you don't know what you're doing, it's best not to attempt a repair!!!
Disassembly is a bit tricky, and there's a variety of different sized screws used; so keep track as you go. First you remove the front bezel (be careful as the two control boards on the lower right need to be disconnected). There are two screws (lower left and lower right) that secure the shell, the rest of the frame is just a snap fit around the perimeter.
Then remove the 6 screws that hold the LCD frame to the rear plastic shell. Careful here as well, as you must disconnect the back light cables AND the signal cable to separate the LCD from the Power Supply / Signal Processing board.
The Power Supply board mates to the Signal Processing board thru a 2x5 pin header. This contains convenient points to check the +12V and +5V supplies. In my case the +12V was OK, but the +5V was reading about +2.5V...not good! THIS IS REALLY DANGEROUS TO CHECK AS THE 120VAC IS ONLY AN INCH AWAY.
Here was the key symptom on my unit. Your's may not be the same. If I disconnect the Power Supply from the Signal Processing board, then the +12V and +5V read correctly (as well as the +16V that goes to the Backlight Inverter section).
However, once I connect the Signal Processing board, the +5V drops to +2.5V. However, the Signal Processing board seems to run correctly off of an external supply drawing about 300mA.
On closer inspection of the Power Supply board, I notice that 4 capacitors had buldging tops (domed). This indicated some stress. These were capacitors C205, C206 (470uF/25V) in the +16V section; and C210 (470uF/25V) and C209 (220uF/25V) both in the +5V section. I didn't have a Capacitance Meter handy, so it was simpler to just replace all four parts with similar values. (There's a lot of latitude in making these substitutions.) But be sure you have voltages a *least* greated than those needed; i.e. 16V or 5V. They used 25V to have plenty of headroom.
After replacing the 4 Capacitors, the Voltages and Blue LED responded normally. After reconnecting to the LCD assembly, all was well. Reverse the disassembly process, and you are ready to go.
nateoceanside@hotmail.com
Aug 06, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
Gateway 19 in flat monitor Model 900G
Does the power button light up or blink at all ?
It probably is the power board/ inverter. I fix many of these.
To TeeKO, did you try moving it back to see if it was maybe a bad household receptical ?
ebaysbammbammfran
Jul 29, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Side Buttons - Not Responding (wrong input?)
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Jan 27, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
LG KE600 problem
same problem with mi LG KE600, when i try to turn it on it just keeps flashing the logo and doesnt do anything else. Does anybody have an answer to this yet?
Sep 07, 2007 | Nokia 1100
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
304 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
