Question about Sony KP-53XBR200 53" Rear Projection Television
FUZZY (SNOWY) PICTURE
The picture is very fuzzy with a snow like effect. I have tried all the inputs and have the same problem. When I go to picture in picture the small square picture is perfectly clear.
  • 3 Answers
I'm working on the same problem with a 53XBR200. I think the failure is in the BR board. PIP video is routed through the BM board and full-screen video gets routed and upscaled through the BR board. Whenever video is displayed in any of the PIP modes, the video looks fine. When you go back to full-screen, static appears with every input and ant. I've tried routing video by bypassing the BR board, but this doesn't fix the video. I think the video processor which receives video from either the BM or BR board is expecting 480p. Since the BR board is no longer available from Sony, the only way of making the set useful is to find a way to bypass the BR board, or repair the BR board itself. Has anyone else encountered and/or solve this problem?
Posted on Jan 02, 2008
  • 1,476 Answers
When you say you have tried all the inputs you are not clear if you mean tuner, vcr, dvd, aux, etc. If you are talking about only the cable input it sounds like you have a bad tuner. To obtain picture in picture there are 2 tuners in your set. This would explain why the small picture is ok while the main picture is bad. You should be able to swap the signals (see your ops manual). Try this. If the snow moves the one tuner is bad. If you have put other signals in (besides cable)such as dvd then the problem is in the matrix circuitry where the two signals merge. Either problem should be easy for a good tech to solve and not cost a whole lot.
Posted on Jun 22, 2006
Amp transmitting fuzzy picture
It could be dirty contacts, corroded connectors inside, or dirty from atmospheric pollution or even dust.
Other degradation may result from a solder joint developing corrosion now, or a diode getting leaky.
It is repairable, but it is a time investment.
Mar 23, 2012 | Channel Plus DA-8200HHR Amplifier
Philips 32 Ambilight PF 9986 TV Picture Problems - Fuzzy & Loss of Picture
What are you using for signal to the set? (Box?) and how are you connected? (HDMI?)
If HDMI try going Component
It may be the box/HDMI hook up causing the problem.
Mar 15, 2012 | Televison & Video
LCD screen Olympus Stylus 1010 snowy and fuzzy with lines
This is a issue with just the LCD it needs to be replaced.
May 25, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Screen looks 'snowy'
Sounds like an electronics problem. Try resetting in the setup window. Remove and replace the battery. If these don't work, definitely take it back to the supplier for warrantee repair. Any problems with that, go straight to Consumer Affairs.
Jun 02, 2008 | Casio Exilim EX-S500 Digital Camera
Fuzzy picture
what cain of tv you are talking about
May 10, 2008 | Televison & Video
Well, I can tell you it shouldnt have anything to do with your not having an HD box. The TV does not require a HD signal to give you a quality picture. The HD box only gives you the enhanced HD signal, but should work as any regular TV without it. How do you have it connected?
Dec 24, 2007 | Memorex MT1701 17 in. HD-Ready LCD...
Snowy picture on certain channels and only sometimes
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Sony KP-53XBR200 53" Rear Projection Television Logo
163 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
