Question about Harman Kardon Audio Players & Recorders
AVR 20 II intermittent loss of sound
My AVR 20 II receiver hav been with me for about 6 years now.
the problem is,the sound will loss (silent) intermittenly.It happen randomly.
its kinda like this normal-silent 2 sec-normal-silent 1 sec-normal again for long period then it happen again.It does not matter if the volume is high or low and happen on all surround option.The receiver display did nok flicker when it happen so its not power problem i guess.I have open the unit and there are no burnt or spoiled component.
Speaker used are Infinity SL50 front speaker,,JBL Flix2 center and surround speakers.
At first i tought it was caused by heat but putting two cooling fan doesnt seem to be helping.
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
SOURCE: Pioneer Multichannel Receiver VSX-D508 (including cd player & tape deck)
receiver on the screen displaying power off
Posted on Apr 15, 2008
  • 5 Answers
SOURCE: DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC, AT49LV002-70TC (IC 817 ) at DSP board (Denon P/N: 262 3010 006).
Posted on Sep 11, 2008
SOURCE: center speaker no sound
had the same problem and SOLVED it.. the problem is caused by bad solderjoints on the pcb with the pre-out connectors on it. the solution is to take this pcb out and inspect it visually for signs of loose/oxidized solderpoints - indicated by a faint gray 'ring' near the soldered wire. just resolder and there you go! an amp as fresh as on its day of birth.. enjoy
Posted on Oct 28, 2008
dunnbiker
  • 8546 Answers
SOURCE: Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
Posted on May 21, 2010
Testimonial: "@dunnbiker Very true on assumptions! I've tried everything the manual suggests. Right now, nothing is connected to the unit, but upon power up, I get the SP:OFF display (which is not seen in the DEMO mode). I will try the headphone jiggling idea and see what happens."
HK AVR 247 no power up
Could be an open internal fuse or power supply failure.
Sep 19, 2016 | Harmon Kardon Harman Kardon H/k Avr20 Mkii...
No sound from tv to speakers
i assume you are hooking up from tv to receiver with an optical cable? Check the settings on your tv. Most tv's have a setting to turn on/off the optical audio output
Apr 21, 2014 | Harmon Kardon Harman Kardon Avr-20 Ii...
I have denon avr-2802.. suddenly no sounds will come out but the power ok.. help me pls..
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-2802-Receivers-manual/id/363bh830/t/2/
Is it silent for ALL inputs including the Test Tones?
Page 33
Function incorrect, Muting, Tape or EXT Input on when it shouldn
Feb 19, 2011 | Denon AVR-2802
I have a hk25 II receiver. It is about 20 years old. It has been working fine but I had to relocate it and now the speakers sound is distant and the balance control does not work. I only have two speaker...
Hi Steve
I have worked on these units in the past as a Harman Kardon service agent. They are decent units and well worth persevering with.
By the sound of your symptoms, the signal is not making it from the pre amp stages to the power amp stages. This can be caused by a few different things.
1. check that the tape monitor switches have not been engaged
2. check to see that the pre out main in connections on the rear of the unit have been jumpered. See page 12 of the user manual for info about this.
You can also download a user manual for the amp from Kardon-AVR-25-II-Receivers-manual/id/390bh145/t/2/">here to assist you with working things out. I suspect that the jumpers are missing at this stage
I suspect that the jumpers on the rear are missing at this stage. Check for that and get back to me.
regards
robotek
Jun 25, 2010 | Harman Kardon AVR 25 MKII
Problem with Denon AVR 1508 in DTS NEO 6 Format
WHAT TYPE OF AUDIO CONNECTION IS USED FRON THE SAT TO THE DENON? IT HAS BEEN MY EXPERIENCE THAT YOU MUST CHECK THE OUT PUT FORMAT OF THE SAT OR EVEN USE A COAXIAL OR OPTICAL CABLE AND ON THE FRONT OF THE DENON PRESS THE INPUT MODE BUTTON TO DISPLAY AUTO
Sep 24, 2008 | Denon AVR-1506 Receiver
Denon AVR-1802
might hav eto buy new control modual parts store hi end parts store order one for u
Jan 25, 2008 | Denon AVR-1802 Receiver
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
Denon AVR-1803 shuts down
I am a Tech in Michigan and have worked on lots and Lots of Denon AV Receivers. These units have Protection circuits for Overcurrent, Dc Protect, 15v Regulator inbalance, Rail Voltage Inbalance, Low Ac Voltage, Low Standby Voltage and Thermal Protection just to name the ones I remember. My guess is you Probably have either Poor Intermittent solder connections or Amp is not Ventillating Properly. Make sure you leave room above Receiver to Vent and You are using no Less then 6 ohm speaker Impedance per ch. Refer to Speaker Impedance chart on back panel . kstahl65@att.net
Dec 06, 2007 | Denon AVR-1803 Receiver
49 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
