Question about Pioneer DEH-1700 CD Player
My radio's dead
I've had the DEH-1700 for a while now. However, yesterday my battery was dead and had to jump start the car using start cables. Since then the radio won't work at all. I'm not sure if the problem is connected to the battery being dead. I have checked the fuse and this is still OK. I would like to take the radio out to check it but don't have the extraction keys (I bought the car second-hand and they didn't come with it). Any simple solutions to removing the radio without the keys and what problems should I check for once removed?
Thanks in advance,
Finn
    President:
  • 624 Answers
Sorry it took so long to get back on this. I just moved from Detroit to San Antonio and am still getting sorted out.
You can use any long slim metal to get the radio out. Something like a couple of butter knives are about the right size. You push one in on each side of the radio between the radio and the sleeve that holds the radio. Push them in as far as they will go near the middle part of the radio. Once they are all the way in they should release the catches that hold the radio in place, then just pull the radio out. The radio may also have a fuse right at the connector for the plug. It will be a plastic blade fuse normally a red one (10 amps) so check that as well. It plugs right into the radio and is part of the jack that the harness plugs into.
Let me know if you need any more help.
Dave
Posted on Oct 25, 2008
2012 jeep dead
Replace your battery. It's dead I feel. You can try to fully charge it up but if you had to replace the fluid in the battery it does not sound good. Make sure your battery cables are tight and clean on both ends.
May 29, 2015 | Jeep 2012 - Liberty
Dead Battery
You will need to get to the battery inorder to do this. If you can't, because the lock is not functioning, you will need to call a locksmith and have the lock replaced. Do this properly, if you don't you could cause more damage than just a dead battery.
Jun 18, 2008 | 1995 Jaguar XJ6
I recently purchased a 2000 Ford Contour SE. It has dead battery and I used a jump box to start the car yesterday.. I started the car once after without the jump box and it cranked up. I went to bed. I got...
have a load test done on the battery as there is a dead cell evident. If the battery is replaced have the alternator checked for output and your problems should go.
Oct 08, 2013 | Cars & Trucks
Got a used pioneer deh 1700 can i ground to the back of the deck? no black wire
The chassis of the receiver normally is connected to its ground, it should work, but if want to look for the missing cable please follow the color sequence at the rear connector, the ground wire is the third starting from the yellow cable, the second should be the red one, for more details about your receiver please check the user manual at:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEH1700.PDF
Feb 19, 2011 | Pioneer DEH-1700 CD Player
Went to start my car yesterday and it wouldn't start. Got it jumped it worked fine. A few hours later started it again and radio went dead car went dead what could it be?
sounds like alternator may not be charging check voltage at battery while engine is running need to see at least 13.1 volts if not have alternator checked and or replaced
Mar 21, 2010 | 2005 Nissan Altima
Deh-1700
try ebay, they have a wide variety of face plates without the radio..
Nov 05, 2009 | Car Audio & Video
Preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Apr 06, 2009 | Pioneer DEH-1700 CD Player
Deh-1700 goes dead on bumps
Loose or striped wire, pull the radio out and check your connections thoroughly.
Mar 19, 2009 | Pioneer DEH-1700 CD Player
2006 jetta tdi radio not working after jump start
battery is dead... have the battery and alternator tested for functionality
Mar 04, 2009 | 2006 Volkswagen Jetta
No power when switch is turned to start.
What was the jump method? NEG to chassis? That should tell you that the ground cables should be suspect - NEG battery to chassis and to engine.
Jun 06, 2008 | 2001 BMW 325
Pioneer DEH-1700 CD Player Logo
271 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
