Question about Philips DECT5112 Cordless Phone
Philips CD240 always show "initial"
The cordless phone alway running out of battery. Even worst the phone unresponsive and hot after been recharged. Change the battery not solving the issue.
Tried to send to Service center and they just replaced the power adapter..
  • Anonymous Feb 10, 2009
    i have the same problem
    i just replaced the phond.
4 Suggested Answers
SOURCE: Philips CD240 cordless phone
need manual for philips cordless phone CD 240
thank you
Posted on Aug 29, 2008
  • 4 Answers
SOURCE: I have a phillips CD240 cordless phone, on the
Hi, I solved this issue this morning. "Searching" means the handset cannot find the signal from its base, and if you check your base, it's more likely than not, dead. In my case, I checked this by pressing any button on the base, i.e. answer phone etc., there was no response (although the handset seems to recharge power fine for some reason).
Therefore, I went and bought a new cheap GAP compatible (binatone 1800 Single at Comet - 14.99). I then set up the base, put it in the registration mode as per the binatone instruction. Then on the Phillips CD245 handset and gone through the above registration procedure... and Voila! It worked.
Now I have a brand new base that came with 1 new handset of its own, and 3 additional CD245 handsets which are all registered with this base. So far, the sound quality is good (no different from the previous genuine set) and they retained all the telephone numbers registered with the handset.
I don't have any high regards to binatone specifically as a brand because our last corded phone system was rubbish and died shortly after 12 months guarantee but to me it looks as if GAP compatible cordless phones have certain life-span however cheap or expensive they are (while handset seem to last much longer). Threrefore, there is more incentive to buy a cheap base new (of any make that are GAP Compatible) then connect your old handset to this base and live on 12 months manufacturer's guarantee and hopefully more. On the web, I saw some comments that are saying GAP Compatible phones and base sometimes do not successfully register each other (despite even being of the same make or brand). Obviously the users make such attempt at her/his own risk but I can confirm that the above combination worked for me.
Just for info, to do the registration successfully, the both base and handset must be in "Registering" mode. First, to get the base in the registration mode, you have to press <page> (a paging function for handset in case you cannot find where they are - usually button that says <page>or speaker with sound symbol on the base) more than 5 seconds, then the base is in the "Register Mode"(though you will hear no beep). You can then go through the procedure you describe on the handset and the handset should beep with assigned number no more than 10 seconds after it flashed "Waiting".
I hope this is helpful.
The above, however, works only if the Base is still functioning.
Posted on Jan 24, 2010
  • 7191 Answers
SOURCE: I would like to download
You can download and print the instruction manual for Philips CD240 (English) in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Thanks for using FixYa.
Posted on Oct 11, 2010
My one-month old philips cd240 worked well at the beginning, but this last one week it's been giving me problems. With battery fully charged, the phone goes totally off whenever the speaker button is...
There is a problem with your speaker as well as your microphone, it can be replaced, just go to any cellphone technician in your area.
Jul 05, 2011 | Cell Phones
Philips SE 455 twin set cordless: The charge lasts less than an hour when using speaker phone, so I am looking for replacement batteries. Phones only 2-3 years old and absolutely fine in all other...
A higher capacity battery should work even better because a fully charged 900 mAh battery allows the phone to operate 50% longer than a 600 mAh battery between charges. I have had good results with Rayovac Recharge Plus 900 mAh in my Philips SE450. This phone will latch and not operate upon ringing if it doesn't like its batteries (probably high internal resistance), even though the batteries test good on a battery tester.
Jun 28, 2011 | Philips 2252 Twin Cordless Phone
Re: Panasonic KX-TC1402 900MHz cordless phone ..... Had "recharge" indicator showing. Replaced battery and seemed to work OK for a couple of months (until the new battery ran down?). Now the...
I had this phone for awhile. finally connected and it worked for awhile. I unplugged to move to a different room now it doesnt work. The in use light does not work.
Apr 09, 2011 | Panasonic Cell Phones
I would like to download English manual for the Philips CD240 cordless phone but don't seem to be able to see it anywhere - please help. Can't access my voicemails.
Oct 10, 2010 | Philips DECT5112 Cordless Phone
Channel Searching message, but phone is right next to unit
If your phone worked fine and this problem just started happening and seems to be getting worse, I would change the battery, even if the charge light indicates that the battery is charging and you "think" the battery is charged.
Most of these weird problems that start occurring in a phone that always worked fine are caused by the battery goinf dead. You can buy a replacement battery on ebay for like $6-$7 with shipping for most models of cordless phones. I sort of rehab cordless phones that I get at yard sales and at goodwills and sell them on ebay. Out of 50 or 60 so far, I have never found a broken one. I have found, however, plenty of phones that initially display all sorts of weird symptoms which are ALWAYS -- and i mean always -- fixed by a new battery. Good luck.
Apr 07, 2009 | Sony Lands Phones
It always losing the line during the cordless calls
* CHECK YOUR AC OUTLET WITH NO LOOSE CONNECTIONS.(remove multi adapters mostly caused problems)
Mar 30, 2009 | Panasonic KX-TG1100 Cordless Phone
Low battery problem
Although your batteries are exhibiting a charge memory effect a little early, it doesn't surprise me too much after the phones are in use for two years.
You need to replace the batteries in your cordless phones. These you can find at any Radio Shack. Once yo have installed the new batteries you want to let both batteries go dead from use, keep them off the charger stand for this break in period. If you can do this your phones batteries will last longer.
For more information on rechargeable battery memory effect read this article.
Regards and thanks for using Fixya.
Jun 08, 2008 | GE 21018GE3 Cordless Phone
I have just bought a Philips CD240 cordless phone in spain, but the instructions afe not in english. Could you e-mail the manual in english to thank you so much
Jan 06, 2008 | Philips DECT5112 Cordless Phone
Philips talk loud and clear
have a philips cd240 duo, have lost instructions,phone showing .....searching.... what do i do? help asap would be fab.
Jan 03, 2008 | Lands Phones
Philips DECT5112 Cordless Phone Logo
831 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
