Question about Samsung SCH-U470 Juke Cellular Phone
Loose top My daughter's juke has gotten loose so that the flip piece doesn't click into place anymore when open. I can see how to get to one screw on the top piece but the other is inaccessible. Does anyone know how to tighten this up? emmbrad
  • 1 more comment
  • mymiloh Oct 20, 2008
    my top is loose and flips open by itself
  • andrew836 Oct 26, 2008
    the phone opens up past 180 deg. is there a way to fix adjust or replace the hinge?
  • Anonymous Nov 18, 2008
    i had the same problem... and i got a new one. now this one is already getting loose.
    Problem Solver:
  • 4 Answers
My phone was doing the same thing, so i sent it in and they tightend the top pice
Posted on Oct 31, 2008
Motorola w845 quantico disassembly
I have never done a w845 quantico but have done several V860 barrage phones in my time. Both of these phones have a similar design. On the barrage if you flip the screen open, on the inside of the flip there are 6 screws, undo those screws and place where you will not loose, then the top part will separate with just a little nudging (front cover from back) the earpiece in the barrage is in a small compartment and has two contacts (no screws just some adhesive) remove and replace, clip the front back together and replace screws. Most important part is to make sure you do not damage the LCD cable in the hinges of the phone.
Dec 22, 2012 | Motorola Mobility W845 Quantico
Dont know how to tighten my toilet seat...i have the studio 2 piece from american standard
There is a plastic cap that you need to flip open. You can do this by prying the flap at the top of the hinge. Once you pop it open you will need a screw driver to turn the screw that is inside/underneath the hinges. Turn the screw clockwise until it is good and snug. then snap the hinge cap back into place by applying pressure to it.
Sep 14, 2011 | American Standard Home
How do I remove the door panel on a 1999 Chysler concorde?
for the front doors:
Remove the speaker cover.
Remove screws holding the speaker.
Inside the door handle, there's a little cover that you can open with a flathead screwdriver. Flip it open then remove the screw inside. Another one of these is in the little armrest cubby. Same deal, flip it open then remove the screw.
If you have sail speakers (close to the window), remove these too. Gently pry the cover off, then remove screws.
The dip on the door towards the front of the car, there are 2 screw to be removed, they are in there deep but easily come out.
At the bottom, there are 3 more screws to remove.
Once you have these screws off, you can feel the door panel start to come off. There are plastic pieces inside the door panel that are a pain to get the door panel off of; you'll have to lift it to remove the panel. Be aware these might break. I found replacements at an autoparts store. One of mine doesn't have 1 of these (2 on each panel IIRC) but there is no noticeable difference.
As stated, this is for the fronts. The rears should be somewhat similar, just screws to remove.
Carefully put the panel back on, making sure the panel rests into the clips in the door panel, or it might feel loose or look off. You might have to mess with the door lock when you put the door panel back on. Good luck.
Aug 02, 2011 | 1999 Chrysler Concorde
It wont print and everytime i try to print it says error #1200
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable2_bing.gif to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges2_bing.gif out of their carriage.
Figure 6 - Displays ink cartridge2_bing.gif carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in2_bing.gif the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Click Here for the Documents
May 03, 2010 | Lexmark X4270 All-In-One InkJet Printer
I get a 1200 error when trying to fax
Lexmark X4270 Error 1200 Fix - Click here for document link
5. Remove the screws underneath the front cover (6 screws), back ofprinter (2 screws), and bottom of printer (1). View the images below tofind where to remove the screws.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
NOTICE: The ink cartridges are all the way to one end. If the X4270 isplugged in, the cartridge carrier is stuck and doesn’t move. Afterfurther investigation a noticeable small black plastic lever ispreventing the ink cartridges from moving. Photo below shows lever upand down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200.Image on left displays lever up. Image on right displays lever down.
9. Lift the front cover open (if not already open) and plug in theX4270. Cartridges should move to center as if preparing for replacement.
Note: The cause of this problem is the spring slides out of place overtime, probably because of ink shed on one end of its loop and loopattachment.
12. Place spring in loop attachment and use hot tip of heated toolto melt top of loop attachment to prevent further errors. Melt top ofloop attachment similar of that to a mushroom top.
Feb 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
Samsung juke broken
you may have broke the spring it is fixable but it may cost a pretty penny if your not doin it yourself carefully take the phone apart there ar screw behind the battery and look just inside so if anythings broken if so take it to verizon so they can get you that part
Apr 21, 2009 | Verizon Communications Samsung Juke Cell...
Cover card open when it's shut
This problem is caused by the little piece of plastic that you flip down to hold the XD card in place. It has a nipple sticking out of it that is prone to breaking off. Unfortunately, this nipple (about 1/16" x 1/8" x 1/8") holds down a little button which tells the camera that the the plastic piece has been flipped down. Once the nipple breaks off, you need to find some other way to hold the button down.
I simply took a small plastic peg from an old boardgame -- a cribbage-board peg might work -- and whittled it down to fit the opening. Remove the XD card and you'll see the small 1/16" x 1/8" rectangular opening. There's a tiny, squarish black button inside. Use a toothpick or tiny screwdriver to carefully press the button in while the camera is on, and you'll see the error message disappear.
Once you get the idea, use a tiny Phillips screwdriver to remove the plastic piece that you flip down. There are two screws to remove, two little metal retaining brackets and a tiny metal rod. Be careful not to lose any of these pieces! Then gradually whittle your piece of plastic so it fits the rectangular opening snugly, and consistently turns off the error message. Then cut it to about 1/8" in length, insert it into the opening, and reassemble the rod, brackets and screws to hold it in place.
Now the little button will always be pushed in and the camera will be functional once again. Since the XD card has its own spring-loaded "locking mechanism" (you push to insert and push to remove), the piece of plastic you flip down isn't really needed in the first place. You can save it, anyway, just for the memories....
Apr 05, 2008 | Olympus Stylus Verve S / ?-181 mini S...
Hp photosmart m425 flash no longer works
I would look to see if wires are pinched going to the flasher.
You have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Dec 30, 2007 | HP Photosmart M425 Digital Camera
Kenmore canister model 116
Yes. Remove the top plate on the power head. Remove the two screws. Flip the power head over. Insert a flat head screw driver into each of the marked slots and separate the two pieces. It takes about 2 minutes.
Dec 20, 2007 | Kenmore 22812 Bagged Canister Vacuum
How do you open a nuvi 660
The ribbon cables are clameped in place. The look like they would slide out from the connector if you pulled then hard enough,... you do NOT want to do that. The black portion of the connector is actually a hinged clamp. With the unit lying on a table, face up as it you were using it; lift the top screen half away for the bottom half and tilt it toward yourself. You should see the ribbon cable and the red & blk wires. For the wide center connector and the one on the right, the black piece hinges up an away from you (towards the top). Try the one on the right first. When you flip it up, the ribbon will pretty much fall out. Pry the wide center one on the ends, NOT in the center. The narrow one on the left tilts donw towrds you. For the antenna, the hinged peice is brown, and it flips up towards the right. This one does not just fall out. It needs some gentle wiggeling. Also, I was able to use a T6 torx, T5 seemed a little loose,... yo don't want to strip any screws or you'll be screwed. SpaceVector
Oct 08, 2007 | Garmin Nuvi 660 GPS Receiver
Samsung SCH-U470 Juke Cellular Phone Logo
54 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
