Question about Seagate Barracuda 7200.7 40 GB Hard Drive
Removed partitions. Now 'My Computer' doesn't see HDD.
Had DOS and nonDOS type OS's on HDD. Used Fdisk to remove a partition and booted each time. Confirmed partitions going one by one.
Perhaps I went too far - too much use of Fdisk?
Bios recognises HDD but 'My Computer' doesn't.
ecosseman
    Scholar:
  • 32 Answers
You may want to use a program called Partition Magic to repartition your hard drive. You can try using the Disk Management Service built in to Windows 2000, XP, and Vista. This is available in "Computer Management" in Administrative Tools in the Control Panel.
Please note that after removing a partition, you need to create a new one then format it before the operating system can read it.
Hope this helps!
Posted on Oct 17, 2008
Partition table error 105 found
#105 Partition starts on wrong boundary
You may need to use the FDISK program from a recent DOS version because earlier versions may refuse to delete HPFS or hidden partitions, and the OS/2 FDISK program may recognize the partition's corruption and refuse to modify it.
In some cases, you can resolve partition table errors manually.
Jun 06, 2011 | Symantec Partition Magic 8.0 (PM80ENK1)...
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
I have an old laptop that partition and hd have been reformatted. I've tried using boot disk but keep getting the message that says, ''save to disk partition not found. So, can't get win98se to load as...
Haven't used win98 for a while so bear with me and this uses DOS COMMANDS too.
If useing restore cd/floppy you have to use a utility from compaq that creates two partitions on hard-drive.
They may have a restore floppy if you need it too.
One for "recovery files" and one for "OS Boot"
AHH, the memories, I still have my 95/98/ME Laptops up and running for older stuff. HP n CQ too.
Restore CD should do it all though.
If no restore CD - have Win98 CD?
if Harddrive partitioned and formated - Just do 1
1. boot from Win98 CD.
Partition n Format
2. Choose boot to DOS (puts u in virtual drive A)
AT PROMPT
3. Type drive letter of CD ( C: D: or E: )
4. Type CD Win98
5. Type Fdisk ( to partion drive)
reboot n do 1 + 2
6. Type format C: ( I do this to ckeck drive for errors)
OR
JUST Boot from CD and follow install instructions.
1 to 6 for if you have problem with Win98 CD setting up Harddrive.
Apr 04, 2010 | Compaq Presario 2140US Notebook
Unable to boot
Hi there.
To run fdisk from DOS, you will need the Win98 boot disk instead of the 95 one, it has more option available to you while you are in DOS mode so a 98 boot disk will do the trick.
Thanks for choosing FixYa!!
May 30, 2009 | Intel Pentium MMX , 200 MHz
Presario cq60 104tu
The master boot record maybe be corrupted or virus infected.
To fix the MBR, boot up with your DOS disk and type fdisk /mbr
Then install XP, and delete all partitions and then create a new partition, then do a full NTFS format on the new partition.
Feb 27, 2009 | Compaq Computers & Internet
Freezing up when installing winxp pro.
MAY BE THIS COULD HELP. PUT YOUR LAPTOP IN FRONT OF A FAN, THEN TRY TO FORMAT IT AGAIN, IT SOUND FUNNY BUT I FACE THIS CASE MORE THEN 3 TIMES, THE LAPTOP JUST TOO HOT DURING THE INSTALLATION (PUT THE FAN WITH LEFT SIDE FACING THE FAN)
JUST SHARING=)
Jan 25, 2009 | IBM ThinkPad T21 Notebook
T30 cant find os
when you start does it come to point where it shows xp and ibm
Jan 17, 2009 | IBM ThinkPad T30 2366 Notebook
T-3104 Recovery is not working
What anti virus program are you using?
You need one that has a recovery disk like Norton has. That way you can get the viruses to be removed that way if possible.
Otherwise you will have to reformat your hard drive and reinstall the operating system.
Jun 15, 2008 | E-Machines eMachines Desktop PC
Seagate barracuda7200.9 80 gig.
Some of the following answer assumes a windows operating or possibly DOS based operating system. If your original OS was not Windows or DOS -- there may be different considerations.
1) Did you lose the contents of both partitions?
That depends were they soft or hard partitions.
Soft partitions are created as files inside of other partitions
If that is what you had allocated in the formatted partition
you have lost their data content.
Hard or physical partitions allocated using FDISK and some other utilities the second partition would still exist.
2) Where are/were your system files. Often but not always they appear as the first partition of the master drive on the primary IDE controller all assuming a PC (based on the master slave comments you have indicated.) (sometimes the second when diagnostics are loaded on the first partition)
a) if the partition on the drive you formated contained the system files yes they must be installed to access anything on the disk for the most part. A significant exception may be utilization of a DOS boot diskette might permit DOS access to the other partitions if they are formatted with the FAT file system.
NTFS partitions and possibly FAT32 partitions may not be accessible to all versions of DOS -- there may be some bootable CD's that would allow access to NTFS partitions without installing an operating system.
Question back from the DOS and older version of windows days and even some more modern operating systens in subsequent actions with the disk did you use FDISK or another utility to rewrite the boot blocks to point to a different partition?
Question this was not a dual boot machine was it?-- if so disregard anything that follows.
Question did the machine boot after formatting the partition and before you started moving the drives around? If so the operating system is probably on a drive you have removed from the machine. It needs to be replaced onto the same cable position it was originally located upon -- probably on the Primary IDE cable master position or jumper setting.
If not reinstallation of the operating to the formatted partition is probably the correct next step. Be careful in doing this because if you choose one of the other partitions that were not formatted it could wipe out the data in them based on the installation process chosen.
Dec 10, 2007 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
Seagate Barracuda 7200.7 40 GB Hard Drive Logo
85 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
