Toshiba Satellite A75-S211 Notebook Logo
Posted on Oct 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It doesn't work on battery
I have a 4-years old laptop Toshiba Satellite A75-S211 which I fixed from the classic (dust) overheating problem following the wonderful recipe shown at www.irisvista.com . After that, the laptop only works when connected to the AC mains although I get a green led showing that battery is charged. Have I done something wrong when I fixed the overheating problem? Thanks in advance
pankaj rautela
Level 3:
Genius:
  • Toshiba Master 1,252 Answers
  • Posted on Oct 17, 2008
pankaj rautela
Toshiba Master
Level 3:
Genius:
Answers
1252
Questions
0
Helped
333432
Points
3358
Check the power option in control panel, also remove the battery then insert it again
1helpful
Ok i did a clean install of windows 7 ultimate on my toshiba satellite a75 s211 then when i do that i cant hear so i get the latest realtek driver from the toshiba website i install it and i still cant...
Issue with your Hard Disk Possibility of bad sector ..on the primary sector... So Download Partiion Magic and Re- Partionnate your Har drive and Re install you windows
2answers
My toshiba fans their a little noisy how bad do i need to replace
Two cans of compressed air can work wonders. I usually use both cans at the same time, just take the laptop outside and spray away. Make sure it's off, of course ;)
2answers
My Toshiba A75-S211 overheats and shuts off.
That is common with Toshiba. Check to see if your fans are running. Also, there may be a lot of dust, hair, etc inside the laptop causing it to heat up. I recommend buying a laptop cooler. I got mine for $10 and I never have over heating problems anymore. Hope that helps:)
1helpful
My Toshiba Satellite A75-S211 computer, will suddenly shut down.
Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
My Toshiba A75 S211 shot off
the issue is likely thermal shutdown (it got to hot) listen to establish whether the fan(s) are working. you will need to take it apart to gain access to the fan area to clean out the dust and dirt.
My wireless on my toshiba satellite A75-S211 is not working. I followed the connectivity doctor on my laptop but it still does not work.
on the front of the laptop the normally is a switch that turns the wireless off and on if it is on you will see a wirless icon lite up on the end or bottom of your pc
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    1helpful
    How do I replace a keyboard on a Toshiba Satellite A75-S211 laptop computer. I cant see any way to get it out. Also, the power button needs to be repositioned... same problem.
    How to take apart Toshiba laptops. Instructions with pics ... 10 posts - Last post: 21 Mar 2006 Toshiba Satellite A70/A75 Toshiba Satellite P25 Toshiba Tecra A1 .... Toshiba Portege 3500 Tablet PC manual. How to remove and replace the ...
    www.thinkcomputers.org/forum/showthread.php?t=632 - 76k -
    Trying to find website that I have seen befoe that has instructions on how to open up the A75-S211
    Problem solved. Lap top stripped apart and that little line of dust got cleared out and now the laptop works as if new. Thanks to the website I posted above that shows how to safely dismantle the A75-S211.
    Problem in dealing with laptop
    My Satellite A75 was also shutting down unexpectedly. The problem was overheating. I sprayed compressed air into the vent openings on the back of the computer to blow the dust and dirt, and then used a vacuum cleaner on the fans on the bottom to **** it all out. This solved my problem.
    Top Toshiba Computers & Internet Experts
    ExpressFiX
    ExpressFiX
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
