Philips/Magnavox TV, model MS3250C321 shuts off randomly.
The TV turns on and works fine for a few minutes and then it shuts off. The red power on LED stays on. If I turn the power off, then on, it repeats the same process. When it shuts off and I press either the Channel Up or Down buttons, the TV turns back on and stays on for another few minutes, then shuts off again.
  • 1 more comment
  • justicedillo Jan 17, 2009
    what is a lamp in a magnavox model ms3250c321
  • skypilot1947 Apr 20, 2009
    We have the same problem as redcjeep with our Magnavox shutting off randomly. What is the solution??
  • skypilot1947 Apr 21, 2009
    I am experiencing a similar problem to redcjeep, with my Magnavox model MS3250c321. It is difficult to keep on, it wants to shot off. What is the solution??
    Master:
  • 505 Answers
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Posted on Oct 17, 2008
Magnavox 46" LCD TV shuts itself off after a random amount of time.
Is there a person in your environs who is mischievous or prone to malfeasance? Someone may be using a TV-B-Gone on you. Check this out:
https://cornfieldelectronics.com/tvbgone/tvbg.home.php
Apr 14, 2014 | Magnavox 46mf401b/f7 46 Hdtv, Lcd 1080p...
Philips Magnavox Plasma TV went off.
The red LED merely indicates that power is getting to your TV. There may have been a power supply failure, especially since your TV is a 2008 model
Jun 28, 2013 | Philips Magnavox 42MF521D/37 Television
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Magnavox 27MS3404/17-Turns off at random
There is a component in the power supply or one of the scan amplifiers that is going off value, and thus causing a protect or shutdown condition.
Take the set back for warranty service, or have it serviced if it is out of warranty. This is not something you will be able to fix yourself.
Jerry G.
Sep 19, 2008 | Philips Magnavox 27MS343S 27" TV
TV randomely turns off
it may just be a static buildup from the dust.
open the tv and blow it out with a air compressor.
if that doest not work then the circuit may be overloading.
remember it stores a charge for days.
Feb 17, 2008 | Philips 30PW9817 30" TV
Magnavox 15
IT IS YOUR POWER SOURCE HAD SAME PROBLEM CHANGED POWER PLUG HAS HOT TURNED OFF SINCE
Oct 10, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Tv randomly shuts off
Replace power relays on power board...
Bill
Oct 08, 2007 | Philips 55PP9401 55" Rear Projection...
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Televison & Video Logo
1,073 people viewed this question
Top Televison & Video Experts
Electro Med Services...
