Question about GE Dryers
Need instructions on installing electric drier-model#dx230deg6ww-serial#sr7714598
    Genius:
  • 1,122 Answers
Are you talking about the power cord or the wall plug or both?mike
Posted on Oct 17, 2008
Where is the serial numbers located on the whirpool washer and dryer. its the basic ones
Normally the dryer model and serial numbers you are looking for is located on the drier door face of the machine where the door meets it. Look up top normally left hand side.
If it is not located there then maybe on the back of the drier.
Please rate me
Sep 13, 2010 | Dryers
Working but air is cold. The drum is turning but there is no heat - so clothes are not drying
your element on the electric drier has burnt out and will need replacement. This element is usually located at the bottom left or right side of the drier. It will need to have the back removed to get to it.
Take model and serial #'s to a parts house for proper replacement
Dave
Mar 05, 2010 | Dryers
MY DRYER HEATS UP BUT ISN'T SPINNING. WHAT COULD BE CAUSING THIS?
belt is either off or broken. You will need to remove the back of the drier to see which one it is. Take model and serial #'s to an appliance parts house for proer part replacement
Hope this helped you
Dave
Mar 03, 2010 | Whirlpool LEB6200 Electric Dryer
My dryer only blowing cold airwhats wrong
the heating elements that dry the clothes is more than likely burnt out. If the drier turns on and the clothes tumble then the element is the only other possible reason for the drier not to heat up. This element is in the bottom of the drier and can be accessed through the removal of the back panel. It will more than likely be in a square metal box. It isn't hard to replace as you will see but you will need to take the model and serial #'s to an appliance parts house for the proper replacement part.
Good luck hope this helped
Dave
Mar 02, 2010 | AEG T57800 Electric Dryer
Strucke
If the drier is electric then more than likely the heating element has burnt out. This element is located at the bottom of the drier and can be accessed through the back. The element looks just like a toaster element. Take the model and serial #'s to an appliance parts house for the correct replacement part and you should be good to go. It is fairly simple to replace as you will see once you take the back of the drier off
Dave
Feb 24, 2010 | Kenmore 500 6952 Dryer
Old GE drier - Is it gas dryer or electric
it's a gas and you need a new gas or a 220 volt dryer.
Jun 24, 2009 | GE DCSR483EA Electric Dryer
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Help me install belt on electric dryer
need model and brand of drier
Dec 30, 2007 | Dryers
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
