Question about Epson Stylus C48 InkJet Printer
IDE ribbon pulled out!
I've been trying to find the socket for the IDE ribbon that's been dislodged. One end of the ribbon is connected to the cartridge carriage, it's the other end which is dislodged. I thought by removing the outer casing (grey cover) that I'd be able to see the socket, but after finding the screw at the back of the printer and pushing forward the wedges on either side the outer casing refuses to budge. So I'm not able take it off and thus look inside.
I'm want to connect the IDE ribbon. Can anyone help?
  • 353 Answers
The "IDE" cable you refer to is the "Flat Flexible Cable" or FFC in Epson parlance. It connects to the Main Board. To remove the top cover, apart from the obvious fixings at the back, you need to release the two hidden hooks at the front of the cover. For this you will need a strong thin strip of metal - an old fashioned ladies nail file is ideal, or a very thin screwdriver might do; it also takes a bit of a knack to do this, so be patient. You will need to lay the printer on its back, but note that in this position, waste ink can spill out of it. Make sure you lay it on a good thick layer of newspaper. Underneath at the front near each corner you will see a narrow slot.
Insert the metal strip in one, at an angle such that you touch the front wall of the case. Slide the tip of the strip up the case wall until you feel an obstruction - this is the hook. GENTLY prise the hook away from the wall and the case will open a bit; do not use too much force or you will break the hook - it is only thin plastic.
Repeat the process the other side. Complete the case removal by GENTLY pushing in the hooks at the back. When you replug the FFC into the main board, make sure you thread it correctly around the guide posts, so that it can move backwards and forwards correctly when the print head is moving. Test the printer before you put the top case back on. You may feel it would be sensible to purchase a Service Manual before you tackle this task - they
are pretty cheap.
Posted on Feb 11, 2009
Imation 11795 driver WindowsXP
IMATION stopped making the "LS-120" (Laser Servo) drive many years ago, when USB-interface memory-sticks became cheaper & faster. Imation did have parallel-port device-driver software for Windows 95/98/ME, but never updated them for Windows NT/2000/XP.
Instead, disassemble the case, and you will find an IDE-interface Imation LS-120 drive inside. Connect the same "smaller" 4-pin power-connector that used to connect to a 1.44 Mbyte 3.5-inch diskette, set the "master/slave" jumper, and connect an 80-pin IDE ribbon-cable, and connect the other end of the ribbon-cable to an IDE socket on the motherboard.
Jul 06, 2014 | Imation Superdisk Drive 120mb Parallel...
How do you connect IDE device to GA-Z87X-UD4H
This particular motherboard does not provide IDE connections for external devices. The safest option would be to use an IDE expansion card that will plug into the PCI bus and provide normal IDE connections for your devices.
A quick search to google for "ide expansion card" will provide many good results.
May 11, 2014 | Gigabyte GA-Z87X-UD4H rev. 1.0 Socket H3...
Wont see slave Hard Drive in a Dell Dimension 2400
Did you set the Master harddrive as master?
Or is your reference that you set the jumper cap, on the jumper pins; of both harddrives to Cable Select?
What are the manufacturer names, and model numbers of the two harddrives?
If you just see something like - WD2500JB, that will work.
How many wire is the Flat IDE ribbon cable?
There are 40 wire versions, and 80 wire versions.
Notice I stated - Wire.
They will both have 39 socket holes that are used.
(40 socket holes, with 1 blocked off)
80 wire IDE ribbon cable has Master harddrive in middle.
Slave harddrive at end of cable.
Little weird, huh?
40 wire IDE ribbon cable, has Master harddrive at end of cable, Slave in middle.
As for, "Computer will not see it."
Not trying to insult your intelligence. Am trying to see if we are both on the same page.............
1) You go to My Computer, and there is no drive letter assigned to that harddrive you just installed?
If it is there, you double-click on it to open that harddrive.
Please post back in a Comment.
Regards,
joecoolvette
Mar 30, 2013 | Dell Dimension 8400 PC Desktop
This Emachine will not boot from HD or CD. The screen only says Emachine.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter check to make sure the first boot device is set to your hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
you can change it to cd if you want to install an operating system
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
Apr 22, 2012 | eMachines T1440 PC Desktop
My iomega prestige 1TB hard drive is not being recognized by my computer. I've already tried with others computers as well, but it doesn't appear to work. The disk is almost full! How can I get...
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps
Aug 24, 2011 | Iomega Computers & Internet
Wont recognize the primary master IDE. Do I need to replace the MB or is this a known problem. Have tried diff drives and cables...
Don't wish to down a motherboard manufacturer, as it isn't good business, but I would use a SOYO mobo for a frisbee.
You've indicated that the primary master IDE isn't recognized?
Is this by looking in BIOS Setup?
Have you tried to set the harddrive's parameters manually in BIOS Setup?
Set the Cylinders, Heads, and Sectors?
The Cyl, Heads, and Sec information for each harddrive can be found by looking at the label on the top of the harddrive.
If it isn't listed go to the harddrive manufacturer's website, and use the model number off of the harddrive, to find said information.
Example using Seagate harddrive,
Barracuda, Model number ST3500830A
500GB.
A) 16,383 Cylinders
B) 6 Heads
C) 63 Sectors
Also depends on what flat ribbon IDE cable you're using.
With a 40-wire flat ribbon IDE cable the primary harddrive plugs into the Middle of the cable.
With an 80-wire flat ribbon IDE cable, the primary harddrive plugs into the End connector of the cable.
(Both styles of IDE cables have 40-pins. Actually 39 as 1 is not used)
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
(Look under the heading - Connecting Your Hard Drives)
Plus you may want to check the continuity of each flat ribbon IDE cable's wires.
Use a multimeter set to Ohms.
Due to the age of these cables they can go bad.
Regards,
joecoolvette
Jul 24, 2011 | Soyo SY-K7VME Motherboard
Pulled the flat ribbon cable from the connecting slot on the hd. Can't seem to get it back in without the possibility of breaking the cable. How can i do it?
if its a flat ribbon 40 pin ide it should have a location notch at each end so you cant make a mistake you might be trying to put it on the wrong way (back the front) upside down
hope it helps you
Jul 08, 2011 | Computers & Internet
When I open Dell 24000 I get an error sign primary drive 0 not found It tells me to hit f2-- but when I do I get no response. A colleague told me it was a loose cable so i have opened the tower but I do...
the hard drive IDE cables are flat, ribbon cables, usually grey and about 3 inches wide. do not confuse this with the floppy drive cable, which will look identical, except that it is 2 inches wide.
the cable could be loose on either the motherboard IDE controller end or the hard drive end, so wiggle it in tighter, or unplug and then re-plug it at both ends, and then try to boot. if that does not work, then replace the cable.
if a new cable does not fix it, then the hard drive itself may have failed. install the hard drive in a DIFFERENT working computer as a secondary (slave drive) by installing it to the middle connector of the IDE cable (IDE cables have a connector for the "master" or only drive at the end, and a plug for a "slave" drive in the middle of the cable), and see if you can access it. it will probably show up as the "E" drive under "computer" or "my computer". if it does not show up, check and see if it shows up under "administrative tools>computer management>disk management". if the drive is not showing up, then it is dead. if the drive works in the second computer, then the IDE CONTROLLER is the culprit.
if the motherboard's integrated IDE controller is dead, you may want to try the OTHER IDE controller socket. most computers from that era have 2 IDE controller sockets, and usually attach the hard drive(s) to one, and the cd/dvd rom(s) to the other. since the hard drive cables have plugs for 2 devices, you can attach both the hard drive and a single cd/dvd drive to the 2nd ide controller socket, in cases where the 1st ide controller soocet no longer works. attach the hard drive to the end of the IDE cable, and the cd/dvd drive to the middle of the IDE cable, as the "master" or boot device should always be attached to the end of the IDE cable.
you can also purchase an add-in, pci card ATA/IDE controller card, and use this instead of the motherboard's integrated IDE controller sockets.
Nov 06, 2010 | Computers & Internet
How do I remove the keyboard on a Samsung R610 laptop. I have been able to remove the keyboard, but can't seem to unclip the cable that connects the keyboard to the motherboard. Is there some special...
The keyboard connector come in two types.
A plastic connector and usually has a plastic tab that you pull to lift the connector off, DO NOT PULL on the ribbon cable.
The other type is, a ribbon cable that is inserted into a plastic socket on the motherboard. To release the ribbon cable, lift up the plastic catch on both ends of the to release the ribbon cable. When you want to insert the ribbon cable, make sure the catch is in the up position before you insert the ribbon cable, then insert the ribbon cable and the push the ends of the plastic catch down to lock in the ribbon cable.
Aug 04, 2009 | Samsung R610-64G Laptop
Trying to add another internal hard drive to Dell Dimension 3000
Ok... one end of the ide cable goes to the board... make sure that's plugged in correctly and has a blue connector.... second... the last drive on the other end has to be the master... the drive before that is the slave... if that setup is not working ensure that the drivers are set for master and slave... also make the power is pluigged into both drives
Robert
Jan 24, 2009 | Dell Dimension 3000® Pentium® 4...
Epson Stylus C48 InkJet Printer Logo
110 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
