Question about Kodak EasyShare DX7630 Digital Camera
Camera won't turn on
I have charged the battery but the camera won't turn on at all. It will download my pics though. Sometimes the zoom won't work at all either. What could be wrong? thanks, Donna Hammock
  • 3 more comments
  • Anonymous Nov 25, 2008
    My DX7630 also stopped powering up. Went from working fine to not working at all, it was not dropped or damaged in any way. If we plug it into the wall it works fine, I purchased a replacement battery and it still wont power up.
  • lodac Nov 25, 2008
    My DX7630 won't power up either. It went from working fine to not working at all, it was not dropped or damaged in any way. If I plug it into the wall it powers up so I replaced the battery but it's still not working.
  • jpadriver Nov 26, 2008
    same here, does anyone have any info on this?
  • chelle12010 Dec 27, 2008
    First the joystick stopped working, now the damn! thing wont power up even after replacing the battery.
  • Eric Pohl May 11, 2010
    is the lcd lighting up at all? It may not be nothing more than a lighter shade of black.
  • 104 Answers
Im afraid its all down to some problem with internal cicuitry if under waranty get the camera replaced
Posted on Jan 20, 2009
My Olympus Stylus 7030 won't focus and shuts off when I try to zoom.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 29, 2012 | Olympus Stylus 7030 Digital Camera
Camera won't switch on, put new batteries in it, took a photo to test, since then it won't switch on.
If you were able to take one shot before the camera packed up it can be that the battery does not have charge on it and so after the first shot it has drained the battery. So check out the charge on it or repeat charging to test once again.
Other wise it can be that the camera control unit is faulty. Try and reset by removing battery for a while and trying once again.
Jul 25, 2011 | Olympus Camedia D-540 Zoom Digital Camera
Hi, my nikon cool pic 3200, zooms in automatic on
Hello
Thank you for using FixYa for your problem
Zoom has had a knock
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Nikon Coolpix 3200 Digital Camera
Samsung camera still not working
I personally have had great luck with the Kodak Z650. It's an inexpensive full featured camera that provides a good zoom ratio (10x optical + 5x electronic = 50x zoom), the convenience of a charging dock that lets you connect to your computer AND charge the camera by simply dropping the camera into it, and plenty of available accessories. I have two of these cameras and I recently gave one to my daughter and her husband. Kodak.com is a good source for these (new & refurbished), and eBay is probably an even better source. AVOID the Kodak printer dock though. Quality is poor, and they are prone to multiple problems.
Don't give up on the Samsung yet, though. The problem you describe is frequently battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing into the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Cameras
Batteries die within 1/2 hour & zoom does not work
Are your batteries good? There are special Lithium batteries that are designed for cameras.
Aug 14, 2009 | Canon PowerShot A590 IS Digital Camera
Lens will not retract after being
the problem is that the lens is out of alignment. if its not making grinding sounds try manually help the lens to reseat itself. if that doesnt work its not ecomical to repair unit cuz parts and labor are about 120-130 dollars.
Jun 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sucking power like crazy!
How old are your batteries? Overtime and after multiple charges,  rechargeable batteries loose capacity and will ultimately not hold a charge at all. Try a new set of batteries and see if that helps.
Nov 24, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Digital camera lithium ion battery
You probably need a new battery....same thing happened to me.
Nov 16, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
Jul 31, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
S2 suddenly draining batteries rapidly
I have the same exact problem. I just now read a possible solution: try opening the battery compartment door and then closing it again to "trick" the camera into thinking it just got new batteries. There is definitely something wrong with the way the camera senses dead batteries.
Jul 28, 2007 | Canon PowerShot S2 IS Digital Camera
Kodak EasyShare DX7630 Digital Camera Logo
105 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
