Question about Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Problem
Had a paper jam, after removing the paper the red light still stays on. The printer were turned down , but the problem says. While turning the printer on one can hear the motor trying to start but then it stops. Please help or direct me to a service agent. Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Paper registration system damaged.  Check all sensors in this system.
Posted on Oct 17, 2008
The online light stays red/error. What can i do to fix this problem? If found a link on fixya but it is no longer available
Light stay red so many problem
1. When this printer is paper jam or any sensor displace.
(But no printer run) I mean your printer not home position.
2.When fuser unite fault
(Heater lamp not on or thermistor not work)
3.Toner cartridge is not position
Feb 16, 2011 | Samsung ML 2010 Laser Printer
The online light stays red and I can not print anything. what should I do?
check the toner cartridge. red light means there is an error in the printer. check for any paper jams. check paper tray settings.
Oct 01, 2010 | Samsung ML 2010 Laser Printer
The online error light is red on my ML-1610 Mono Laser Printer any ideas how to fix this?
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Jul 16, 2010 | Samsung ML 1610 Laser Printer
ML 2010 Laser Printer: I HAVE A SAMSUNG 4200 IT IS SHOWING PAPER JAM, BUT...
you may want to check again on the printer.if it show paper jam.
open up the fron door and bnack door. remove the toner and check if there is any small pices of paper still jam in the printer.
if not try and see if the fuser flag is not sitting properly. you might need to do small adjustment.
May 18, 2010 | Samsung ML 2010 Laser Printer
I removed a paper jam. red light is still on (not flashing).
There is probably still paper stuck in the paper path, this is very common. What happens if you load it with paper and press the test button?
Feb 08, 2010 | Samsung ML 2010 Laser Printer
Hellow!!!! everyone!!!!!!!
I have found that when this happens the cartridge is not aligning with the micro switch and so take it back out and as straight as you can push it in until it is locked and try again. It will stay red a bit before trying to reset. Even if you turn the power off it will sometimes take about 15 seconds to attempt to start.
I have found when this happens sometimes 5 attempts will get it to work. Easy to replace the cartridge as it is NOT the printer but the cartridge in most cases.
Streak www.streak.asia
May 08, 2009 | Samsung ML 2010 Laser Printer
My samsung ML-2010 JUST DOES NOT WORK ANYMORE!
Is it connected directly too the computer or to a network?
What it sounds like is that you are having a spoiler problem, the computer is intialized but its not getting the info to print. Or it could be a printer malfunction, something mechanical isn't working right in the printer. If you've removed the ink cartridge and replaced it, it could be out of place or not seated right. Other components could be locked up. If the light goes red could you tell us what the error message is? And have you looked at your user guide for information on possible errors?
Aug 18, 2008 | Samsung ML 2010 Laser Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Printer ML2010 not responding
On Line/Error LED
lights red
receiving data.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Red light Samsung ml 2010
I had the same problem and I finally solve it!
I simply took out the fuse and put it again in the cartridge, i don't know why, but it works
Riccardo
Apr 25, 2008 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
307 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
