Question about Toshiba Satellite M35X-S109 Notebook
Black screen, won't boot up, fan kicks on for a few seconds only, then powers down
When I attempt to turn on my laptop, there is a very faint image on the screen. It will load to the sign in page and then the laptop powers off. The fan kicks on for only a few seconds. Tried turning it on with only the battery and then plugged into the power source. Same thing happens. Any help would be greatly appreciated.
  • flopyou Oct 17, 2008
    I tried plugging in an external monitor, but nothing happened.
    Genius:
  • Toshiba Master
  • 1,250 Answers
Check the display on the external monitor through the vga port, if the display is fine , then its the problem of your laptop screen, some time this is due to the cable that gives display to the screen, take it to the technician and checks there
how do you like the solution rate it please
Posted on Oct 17, 2008
  • pankaj rautela
    pankaj rautela Oct 18, 2008
    CHECK THE RAM ALSO, IF THE PROBLEM REMAINS THE SAME, THEN ITS THE PROBLEM OF *********** BOARD
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
Black screen probook
Change the power settings from the control panel. Its in advanced power management.
Oct 01, 2013 | Computers & Internet
Toshiba L745 laptop will not boot up. Get black screen and the hdd light is blinking. Cooling fan speeds up and slows down. Don't get any activity on it at all. Was working last time I used it about a week...
Unplug the power and take the battery out. plug it back in after 5 min then turn it on. see if you can see a faint image in the background. the LCD backlight could of went out.
Sep 11, 2013 | Toshiba Computers & Internet
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Lenovo Z570 powers on but screen is black
if you have an external monitor or a smart TV you can hook it up to that to see if it even works. If it works then you look real close to the screen of the laptop without it being hooked up to the external screens and see if there is a faint image on the screen or you can do this part first. If there is an image but still dark check to see if the brightness is turned down. On the keyboard you will see a sun and moon shape on the F keys just press the FN key with the key for the brightness for a few seconds if it doesn't come up you may need a new screen or power board for the laptop.
Apr 12, 2017 | Lenovo IdeaPad Z570 Notebook
I have an Insignia NS-LCD37 was working perfectly fine, all of a sudden the TV went black, I would turn the TV on and you would get the
Most likely you have a fault in the back light circuit. To verify this, turn on the set, when the screen goes black, take a bright flashlight and shine it on the screen. It may be easier to dim the lights in the room so that you can see the faint image on the screen. If you see the faint image, you indeed have a back light problem. You will need to get a diagnoses performed on the set to track down the problem
Nov 22, 2012 | Insignia NS-LCD37 37 in. LCD TV
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Problem with Fan - Dell Laptop Inspiron B130 ?
If the fan is dead, then the laptop will shut itself off after a short while to prevent heat damage. It is normal for the fan to spin up when you turn on the laptop and then stop turning. The fan will kick in again when it is needed as heat builds up. The system fan has absolutely nothing to do with the lcd lighting up.......seriously.
If the laptop is running, but the screen goes dark after a few seconds, it sounds more like the backlight on the lcd panel is shot. From what you describe, I assume that your lcd is not 'lit up' at all, but you can see a faint image on the screen. If this is the case, then either the inverter board is shot, or the backlight for the lcd panel is dead. You can try calling Dell at 1-800-www-dell and try to purchase an inverter board. They are cheap, and it would be worth the gamble to buy one, because if the backlight is shot, then you need a new lcd panel - $350+ (the backlight is part of it and not replaceable). The inverter board is located at the bottom of the display module, right behind the dell logo at the bottom of the display. It's quite easy to get at.
Here's a good test. Shut the laptop off, and attach a computer monitor to the 15 pin vga connector at the left side of the laptop. Turn on the laptop and the monitor should show you an image. If not, try holding the blue 'fn' key and press and release the f8 key. This should switch you over to the external monitor. If the laptop works fine when connected to an external monitor but has no image, then it's definitely not the fan, and you should try an inverter board. If still no good with a new inverter board, you can still use the laptop with an external monitor.
Hope this helps!.......let me know how you make out.
Dec 12, 2009 | Dell Inspiron B130 Notebook
M35X Screen went black and will not come back on after shut down, reset and power up
Try to connect to external monitor and see if you see anything. Of course when you do that you have to hold at the same time fn key and the key that has a blue picture of computer screen.
Jan 17, 2008 | Toshiba Satellite M35X-S149 Notebook
Toshiba Satellite M35X-S109 Notebook Logo
146 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
