Re: Toshiba satillite A215 won't boot up. No sounds from...
Connect to the external monitor through the vga port of the laptop, check the display, if the display is there then its the problem of your laptop screen
like the soluton or not rate it please
turn off your laptop by hold your power..ten turn on again and try to press f8 when it booting..go to safe mode and restore it by go to all program, accessories, system tools, and system restore
check to see if you inserted router name and WEP password correctly in your son's computer. I'm thinking you were tired when you got to your son's puter.
regards,
Digital Denizen
rate us and ask another question if it doesn't work
My Toshiba A215 starts up but won't boot from any source_CD,external floppy, hard drive,etc.. I swap memory,CPU,hard drive ,nothing works,have any one got any solution?//
THANX
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device. TOSHIBA BIOS PASSWORD DONGLE You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15 Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
you should see the post screen if the monitor is working. try hte fn and the monitor or display key. some laptops toggle the display this way. another possibility is the lid switch that shuts off the display when you close the lid. and it could be heat damage.
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
It sounds like two possible things. One thing may be that your screen is not working anymore. Can you get a monitor and plug it into your port located on the side of your laptop? If your screen pops up on the monitor this tells us your screen is either in need of replacement or a connection may be loose.
If that is not the case......
Another thing is your hard drive may not be initiating. If you feel confident enough I would open the back where the hard drive is located and make sure the hard drive is not loose. Does it give you any beeping sounds when you turn it on? Can you count the number of beeps? This will tell you what the problem is on boot up. Also, is it a black screen with a cursor blinking?
It sounds like the motherboard is bad. There is no power being sent to the fan and that means that somewhere in the the mother board is not sending the info.
