Question about HP Pavilion dv1000 Notebook
LAPTOP WON'T BOOT UP - ORANGE POWER LIGHT FLASHING
The MC was booting up - i left it for a moment and when I came back the screen was black & the MC seemed 'dead'. Prior to my leaving it a message came up bottom right hand corner which said something like '9 mins power' or something. I thought maybe that was to do with the battery but i rarely use it on battery. It was connected to mains power as usual. When i pressed the ON button nothing happened, it didn't even depress as normal and when i removed my finger the orange power light (? Looks a bit like a lightning bolt, second from right and next to the disc light - which wasn't on) flashed a few times then nothing. My husband thinks it might be the transformer which has a label on- it saying 'replace with HP spare and the numbers 33 (or it might be 38) 1090-001. I can't find the manual... will take it to PC world on Monday but thought I would try here first to see if anyone has any tips to save me the trip!
  • EJennyJ Oct 20, 2008
    Thank you for responding, pankaj - we did try that but the battery is still dead. I took it to PC World who informed me that the adaptor was the problem... so I bought a universal adaptor, set it correctly for my laptop (which is a HP nx6325) ... and it still doesn't work! So we now think the battery has gone beyond help and I may have to purchase a new one... and of course the HP website lists batteries, one of which looks almost exactly like mine with one small difference and my laptop model is not listed amongst the compatible products.... so I shall keep looking!
  • 91 Answers
This was an odd one to fix. I found apon opening the machine that the heat sink was completly blocked with fluff (Picture Uploaded) so I removed it and cleaned it up.
I then removed the CPU, cleaned that of thermal paste and cleaned the pins with some universal lubricant (WD40 is fine, just make sure it's not wet when you put it back in!). I then applied new thermal paste (Get this at Maplin in UK) and re-assembled the unit.
Before powering on I removed the motherboard battery for 30 seconds with the mains power supply removed and the main laptop battery removed. The motherboard battery on this model was located under the WiFi card in the RAM bay and can be accessed by removing just the ram cover.
I then inserted the battery and the PSU power and switched it on. It booted to the CMOS screen where I updated the correct time and date, saved and rebooted it and it has been fine since.
I doubt this is a power supply error as the voltage output was correct when tested. Also this supply did not have the data pin (often found in Dell machines to tie you to replacing the PSU with Dell branded ones only) so it wasn't a data error.
Another odd thing is that when it had the flashing light error it would not turn on with just the battery installed even though the battery tested as fully charged. Apon repair the battery runs it just fine on its own.
You could just try removing the battery, PSU and motherboard battery (under the WiFi card) for 30 seconds to see if this fixes it, as it may do. I would then go to HP's website and see if there is a BIOS update under the 'Drivers & Downloads' section for your model. This could be a BIOS error that may have been corrected since your model was released or last updated. I am unable to perform this task at the moment as this is a customers machine and has a password. I shall however advise them to do this.
If you do need to strip it, I should warn that the plastic bezel above the keyboard is a bugger to remove. Make sure you have removed all of the screws under the battery as two of these secure it. Then prise up each end with a thin flat blade screwdriver or Stanley blade and push it up and towards the screen with some effort to unclip it.
Hope this helps some of you out, please rate and let me know.
Phill.
Posted on Mar 22, 2010
    Genius:
  • HP Master
  • 1,250 Answers
For a good battery life of the laptop its need proper charge and discharge but its not the case in yours as you have said that you rarely use on batter, .........so right now remove your battery then insert it, hope fully this may solve
please rate this solution
Posted on Oct 17, 2008
1720 s.m.a.r.t HDD detects imminent failure the computer cant boot-up.
if you haven't got a good back up, external to the hard drive, it may be too late
dead hard drives are mostly un recoverable
take it to a computer repair shop to make sure that it is not a boot problem
if the hard drive is failing, replace it with a solid state hard drive that has no spinning discs to fail
Jan 13, 2017 | Computers & Internet
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
How to hard reset a WM8880 laptop
Power the unit off (holding power buttom) and selecting Power off, then simultaneously hold the "back" button and on button for about 8 seconds. When the android icon appears, press back buttom, in the menu select wipe data/factory reset pressing the home buttom and then press the back buttom, in the next screen select "yes delete all user data" pressing back buttom, and in the next screen select "reboot system now" with the back buttom and wait.
Nov 29, 2014 | Computers & Internet
My SONY VGN-N 130 G Screen Shows sony logo and freeze can not go to home page or any functions ?
Try boot it up by pressing F12 and enter secure mode. Then you shoose "repair". Petter
Oct 17, 2014 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
Button keeps blinking
It sounds like it could be either the battery is going bad and not holding a charge or the adapter is. I have had really good luck with similar problems going to places like Batteries +, and large electronic retailers, and my favorite the small local mom and pop computer store; where I end up asking them If I could try one of the adapters from the floor model to eliminate if is a faulty adapter. Other then that I'd if its not out of warranty contact Acers online chat support at http://us.acer.com/ac/en/US/content/service
Jan 19, 2014 | Computers & Internet
P850 049 laptop
Take it back to the place of purchase and get a replacement as it is under warranty.
Do not try to fix it yourself as you may void your warranty.
May 15, 2013 | Computers & Internet
I can't hook my monitor up to my pc I have a dell optiplex gx620 Sff
On the back of your PC there is a blue 15 pin video connection. Connect your monitor to this video connector, power up your monitor the boot up your PC.
Mar 23, 2013 | Computers & Internet
How do i reset my computer to an earlier date?
Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
Jul 27, 2011 | Computers & Internet
Freezes on the warm boot screen MC9000
This can be for a number of reasons.
First thing would be to try and cold boot the device:-
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger
If that fails next thing would be to try and re-flash the operating system. This is done by using an SD card and loading the latest operating files onto it. The SD card slot is located under the keypad. A cross head screwdriver is required to remove the keypad. Search on symbol software download site for the latest. The download also has a readme with detailed instructions. Once the files are on perform a cold boot.
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger. Drop the terminal in a cradle so that it runs on external power.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 09, 2009 | Symbol MC9000-G Portable Terminal
HP Pavilion dv1000 Notebook Logo
5,046 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
