Question about Onkyo HT-S760 System
Connecting onkyo 576 to sony xbr lcd tv
We have just purchased a onkyo tx-sr576 av receiver and a sony xbr lcd tv. We have the HDMI cables connected as described but cannot work out how to get surround sound when watching tv. We used to have this receiver connected to another tv via a set top box and it worked fine. but this new tv has an internal tuner so we no longer need the set top box and now cannot get surround to work when watching tv.
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Posted on Jun 02, 2008
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
  • 120 Answers
SOURCE: Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Posted on Feb 12, 2009
SOURCE: Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Posted on Apr 19, 2009
  • 5 Answers
SOURCE: I HAVE AN ONKYO TX
The symptom you described can be caused by any number of things. I always start with the output power transistors which are the first things to blow with a speaker output overload condition. Unplug the power cord to your unit, remove the top cover and use an ohmmeter to check resistance from C to E on all 10 of the power transistors (Q6050 thru 54 and Q6060 thru 64) attached to the large heat sink. Blown transistors typically read <1 ohm, compared to good transistors that are >10k ohms. If you find a bad transistor it will need to be replaced.
Posted on May 03, 2009
My Onkyo tx-sr707 AV receiver no longer produces any sound in any of the modes: ie, TV cable, radio etc.. I still get a picture through my cable's hdmi connection, That hdmi connection runs from from...
You may know by now Onkyo has severe HDMI board problems. If your unit comes on with no sound, forget about the heatsink solution. The second solution of wavesoldering the Ic's is chancy at best, and requires someone with proper soldering equipment for Surface mount flat pack ic's. I've seen a hear gun attempt blow the surrounding electrolytic capacitors out of their cans. Onkyo extended the warranties for many of their high failure boards. Check the following site to see if you qualify for the exchange/repair/replacement: http://www.avsforum.com/forum/90-receivers-amps-processors/1652514-onkyo-acknowledges-failed-units-extending-warrranties-until-2018-a.html.
Dec 17, 2017 | Onkyo TXSR707 72 Channels Receiver
Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Sep 10, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Feb 12, 2009 | Onkyo TX-SR506 Receiver
Configuring the componet out ?
u can buy a converter for output to configuring the tv. the converter is to connect the cables output to the player.
Dec 24, 2008 | Onkyo TX-NR801 Receiver
DVD signal received in wrong aspect
PRESS SETUP GO TO MISCELLANEOUS PRESS ENTER THEN DOWN TO OSD SETUP PRESS ENTER AGAIN AND DOWN TO MONITOR AND CHANGE TO 16.9.
HOPE THIS HELPS.
CABLE GUY.
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Oct 22, 2007 | Onkyo TX-SR604 Receiver
Onkyo HT-S760 System Logo
105 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
