Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Unable shut off line to ice maker(leaking)
Pin hole leak shooting water 5'-turned shutoff under sink-still leaks as a steady drip-have a bucket under it-only way to stop is to turn off main and
unplug init.
    Genius:
  • 1,122 Answers
Cut the bad piece out take it to home depot and tell the guy you need a double end quick connect and you can install the 2 ends together with it and your done,let me know how it turns out-mike
Posted on Oct 17, 2008
  • MIKE major Oct 18, 2008
    i give you a fixya answer,you give me a helpfull rating,what's up??????is your icemaker line leaking or the water valve under the sink?
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
What would cause my ice maker to leak into the plastic ice bucket?
The most likely cause is the fill valve is leaking and causing the ice maker to overfill. Try a new fill valve. Usually located on the rear of the appliance. (where you hook the water line to).
May 02, 2014 | Whirlpool GZ25FSRXYY
The pan at the bottom to hold water (Condensation?) is leaking. Never leaked before. We pulled out the fridge (Its on the freezer side) cannot pull it out. Water dumped. It took 2 /3 days to fill up...
The normal run of the fridge will not normally fill the pan, so you have a different source. In this model the water valve is next to the pan. Either you have a leaking water valve or a bad connection to the water valve. Either way the problem you will find is the water valve or line is the cause. Look from the from with a flashlight under the the freezer door, dispense water from the door and watch the valve.
Good Luck
Sep 10, 2011 | Whirlpool GS6SHAXMQ Side by Side...
Automatic ice maker has a steady drip of water in the freeze, turned off water source, but still dripping
It is possible that the Ice Maker water valve and the Shut off valve are both leaking. Try disconnecting the water line, turn the valve to the right to be sure it is off first. If the line drips then you will know your cut off valve is bad or not. Also clean the coils under the box while it is out it will improve its efficency over all. Replace any panels you remove to clean, use a vac with long extension as dust is quite nasty.
Oct 17, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water leaking from under refrigerator
Analyzing the likely source
Instructions
STEP 1: Move the refrigerator out from the wall and look for the location of the leak. STEP 2: Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem. STEP 3: Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker. STEP 4: Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking. Fixing a condensation problem
Instructions
STEP 1: Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely. STEP 2: Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly). STEP 3: If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls. Fixing a drip-pan problem
Instructions
STEP 1: Pull off the grill that runs along the bottom of your refrigerator. STEP 2: Locate the drip pan, using a flashlight if necessary. The pan should be sitting on top of a set of black condenser coils and directly below a drain tube that carries water from your freezer when it is in defrost mode. STEP 3: Place the drip pan in your sink and fill it with water to test for leaks. If it leaks, order a replacement from your appliance dealer. STEP 4: If the drip pan doesn't leak, clean it with warm, soapy water, then reinstall the pan and the refrigerator grill. Fixing a clogged defrost drain
Instructions
STEP 1: Locate the defrost drain. It should be a round hole or a channel running under the vegetable and fruit bins in the refrigerator or along the floor of the freezer compartment. STEP 2: Inspect the drain for clogs and remove any debris. If necessary, use a small screwdriver to break up debris that's trapped in the drain hole. STEP 3: Fill a meat baster with hot water and force it through the drain to make sure the clog is gone. If the drain is operating properly, the hot water will fill the drip pan. Fixing a leaky ice maker
Instructions
STEP 1: Pull the refrigerator away from the wall and locate the copper water-supply line. It runs from the house water line to the refrigerator water-supply valve. (To get to the supply valve, you may have to use a screwdriver or a nut driver and socket to remove your refrigerator's back access panel.) STEP 2: Inspect the copper supply line, the supply valve, and the plastic supply tube that runs from the other side of the supply valve to the back of the ice maker. STEP 3: If a connection is leaking, tighten it with an adjustable wrench. If either the copper supply line or the plastic supply tube is leaking, you need to replace it. STEP 4: Turn off the water supply. The valve may be under the kitchen sink or connected to a cold-water pipe in your basement. STEP 5: Remove the faulty line and take it to a hardware store to get an exact replacement. STEP 6: Install the new line, tighten the connections with the adjustable wrench and turn the water back on. Overall Things You'll Need
Meat Baster
Adjustable Pliers
Adjustable Wrench
Soap
Nut Driver And Socket
Replacement Parts
Flashlight
Screwdriver
Who Can Help
Find Prescreened Appliance - Repair or Service Contractors at ServiceMagic.com
Overall Tips & Warnings
To keep door gaskets clean and supple, wash them twice a year with warm, soapy water, then coat them with a light film of petroleum jelly.
Some refrigerators have an internal defrost drain that is meant to be serviced by a professional. If you can't find your drain, call a pro.
To prevent possible electrical shock, always unplug your refrigerator before working on it.
Put carpet scraps or another soft material under the front legs before pulling your refrigerator away from the wall. Otherwise, the legs could damage the flooring.
Aug 05, 2009 | GE Refrigerators
Amana SBD21VE No water to ice maker
your water line to the fridge is most likely leaking. You should turn it off right away. The line turn off is either behind the fridge or under sink. sometimes its in basement. The line is very easy to replace. You can get the plastic ones at home centers for under 5 bucks.
Jun 08, 2009 | Amana ASD2326HE Side by Side Refrigerator
Ice maker drip into ice bucket and manual cycle leaks more water
Need to take the ice maker out to measure the amount of water input into the ice tray. In this case the tray was already full (from the leaking valve). The spillage I saw was just the tray overflowing. Time for a new valve.
Apr 28, 2009 | Kenmore Refrigerators
Refrigerator leaking water
There is normally a small shutoff valve installed in the water line servicing the ice maker; you might shut off the flow of water until you locate the problem.
Most drip pans can be slid out but it would be wise to lower the level with sponges or similar to avoid any more spillage than you already have.
If the 'knob' is centered it is probably the release knob for the grill, behind which is of course the drip pan.
Before damning the ice maker (although they are among the most unreliable devices known to man), I would pull the fridge out and examine the fitting where the water line is attached.
Any lime buildup or green corrosion around the fitting would imply that the leak is external to the cabinet and the leaked water is only accidentally making it to the drip pan.
If you haven't been getting blocks of ice in the cube storage bin, the shutoff valve is apparently working so you may get lucky locating the source of the leak.
Jul 07, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Feb 26, 2008 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
55 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
