Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy tiller tines
Looking for direction on the proper configuration for installing tines on Troy Tiller.
Mike
  • Anonymous Mar 31, 2014
    will not atart
  • Anonymous Apr 01, 2014
    Ariens rear tine tiller
  • 48 Answers
They should point inwards and towards the rear of the machine
Posted on Oct 17, 2008
Tiller moves to fast on a troy built rear tine
what do you mean - are you sure this is a husqvarna or a troy built tiller?
May 07, 2012 | Husqvarna PRRT850X 960920015 CA 17" Rear...
I WAS JUST GIVEN A TROY BILT 5 HP REAR TINE PONY ROTA TILLER. THE DECAL WITH THE MODEL NUMBER ETC. ON THE TINE CASING IS UNREADABLE. DO YOU HAVE ANY IDEA WHAT MODEL THIS MIGHT BE? I WOULD LIKE TO GET A...
The serial # of the tiller should be stamped directly above the right wheel on the transmission housing. This should give you more info to work from.
May 02, 2011 | Troy-Bilt Pony Garden Tiller
How do I get the wheel off of my rear tine tiller? They appear to be pressed on and use a bolt or pin to retain them, but I have soaked them with penetrating fluid and used a puller but have not had any...
Did you ever find a solution to removing your tiller wheel ? I have the same problem, tried pullers, heat, hammer, Wd40, everything. I would appreciate your input. Mike. mglobna@yahoo.com
Apr 09, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I have a Troy Bilt Tuffy Tiller H30-35387S Ser 91330. The only number I can find for the tiller is on the shaft housing between the tines and the wheels and it is X0010527. I need a manual or parts diagram...
You've got the right serial number - it appears you've got one of the older Tuffy's. I'd suggest keeping an eye on Ebay for the manual you're looking for. I find them out there with some regularity. You can't get them from a dealer anymore because this Tuffy was sold by Troy Bilt before they went bankrupt and MTD bought the assets.
Jul 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Need a manual
here is the Tuffy webpage at the troybuilt.com... directly under the photo of the tiller is a gray "download manual" link...
best wishes,
k
May 28, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
May 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Need manual for a Troy-Bilt Tuffy tiller
Your engine number is wrong by only one character. The proper number is H30-35387S you had a 5 instead of the S. You can download the engine manual from Tecumseh. I don't know about The rest of the tiller. (I have the same tiller).
Feb 21, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
259 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
