Question about Philips Audio Players & Recorders
Turntable 45rpm speed has stopped working
33rpm is fine but when I depress the speed selector push-button for 45rpm the speed increases for a second and then decreases to below 33rpm and fluctuates under that speed. The deck sits on a platter which is driven by a belt around it and the motor spindle. The speed of the motor is controlled via the push-button selector which pushes a rod onto a lever which alters a switch position underneath a small PCB that connects via 4 wires to the motor.
  • kimreklaw Oct 20, 2008
    Brilliant! I'm no techie but I took the platter off, removed the pcb and found that the lever wasn't doing what it should. I tinkered, applied some pressure to the contact strips and, lo and behold, it now works! Thanks, ashburton, guru indeed!
  • 417 Answers
Check that the lever is actually making the contact with the 45 rpm switch position and completing the circuit as it would seem everything else works. The only other thing it could be is a break on the pcb, but that is unlikely.
Posted on Oct 17, 2008
How can I fix the speed myself on a Steepletone ST918 record player ? 33rpm plays LP's at 45rpm !!!!
I am not familiar with this brand, but many turn tables adjust the speed using a rubber wheel and a turntable motor with different shaft sizes. The shaft is ground smaller in steps the further from the motor. As the rubber wheel is moved up the shaft, the slower the turn table spins. Most times you can lift the turntable up (may have a clip to hold it in place) and look to see if the wheel moves up and down on the shaft as you shift speeds.
Jul 18, 2014 | Wurlitzer Jukebox 1015 One More Time...
Record play 45rpm
just buy a new unit if you ain't got friends to help you.... and45.
Or see how far your goes?
Jan 28, 2014 | Stanton T62 Turntable
Technics SL B210 - New belt, but still "plays up" on 45rpm
Do on thing Oppen the Turntable and replace the 5 electrolytic capacitor ( 330mfd 16V,3.3Mfd 25V, two 2.2mfd 25V and 47mfd25v )in the circuit board. Also try to replace the 2 Vriable resistor ( 2K and 5K) in the circuit board of which one is for setting the speed of 33.33 and another for 45 rpm. If you need the service manual then just get in to the following link. You have to wait for some time until you will get a notification that Get the manual.
Ajin
Service manual
Feb 27, 2012 | Technics SL-DZ1200 Turntable
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Nov 25, 2009 | Crosley Audio Players & Recorders
GOING FROM 45 TO 33
I don't know if this model is direct driven or by belt. If it's belt driven then the belt could be fitted incorrectly, or faulty. Another possibilty is that there's a fault in the motor control circuit.
Jul 28, 2009 | Gemini PDT-6000 Turntable
Daytron All in one Turntable, 8-track & fm
if the turntable is belt driven.... try replacing it... maybe the belt is worned out
Jul 19, 2009 | Audio Players & Recorders
Sl1200mk2
It's very simple. Next to the "tone arm" (the thing you pull across towards your vinyl, and place down to produce sound) is a silver piece which you slide up and down to change the pitch (the speed) of the vinyl. This can be increased even further by changing the 35rpm setting (button near the start/stop button) to 45rpm.
Hope that helps
Jan 30, 2009 | Technics SL-1210 Turntable
Turntable speed
most of these were belt driven, if that the case check to see if the lever is connected moving the belt to the slower pully
Dec 31, 2007 | Sony PS-LX250 Turntable
269 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
