Question about Sony Handycam CCD-TRV608 Camcorder
Hi 8 Tape Will Not Eject
The ejection unit will open half way and close back up.
  • 827 Answers
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to eject the tape. You may be getting an error code that indicates the reels are not turning for some reason. You can assist the reels turning as the tape is ejected if you stick a small plastic pick or a toothpick into the reels to assist the reels turning and then you may be able to remove the tape.
Chris (ziraffa)
Posted on Dec 19, 2008
I have a Pioneer LaserDisc, model cld-v850, where the the ejection button would not close the disc inserter. It only closes half way. Any help is much appreciated, thank you!
Unplug pc, open cabinet and look for dust and debris , clean with compressed air.
If it's still dirty use 50/50 distilled water and alcohol with a swab. Allow 30 minutes before plugging back in.
Dec 10, 2014 | Pioneer Televison & Video
Tip
The CD/ DVD/ Blueray player tray keeps opening and closing!
First make sure the "Eject" button has not stuck while pushed-in. Clean the Tray window/opening and the inside of the front part of the tray. Then try to push the tray in a little bit when closed and drag it out while open! By the time dust gathers on the greasy tray rails resulting it not to open and close to the full extent. If it helps but the problem comes back, then you should open the box and clean the rails more thoroughly. Have a look at the switch that senses the tray state (open/closed) too. OBS! That is not the same as the "Eject" button! Switch placement is device model deppendant but it is usually placed on the stationary part of the disc-player unit under the front end of the tray in the middle!
Some units do eject a disk they don't recognize. That a player can't read a disk could be a result of incompatibility, dusty optical lens or faulty/old laser. You may clean the lens by using a "Cleaning disk" or blowing with an air spray(or a straw with your mouth) through the opening of the tray.
Good luck
Please rate positively if helpful, thanks!
/SciPhinx
on May 06, 2010 | Televison & Video
Dvd will not eject
Someone is going to have to open the unit and LOOK to see if disc jammed or out of position---it is possible in that case to gently with a Q-tip etc to move it a bit back and then unit may work.
Look only to see what is happening when you try to eject first.
Nov 03, 2012 | Televison & Video
DVD side will not open, for the longest I could only get the DVD side to open if there was a disk in the slide yesterday the DVD side was closed with NO disk in it and now I can not open it
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. If this doesn't open the unit, you will have to unplug the unit and remove the cover. The cover is held in place by two silver screws on each side and five silver screws on the back of the unit. Once the cover screws have been removed, you can slide the cover towards the back halfway and then take the silver cover (held in place with two screws) off of the DVD player. Once the DVD cover is removed, insert a disc in the player and re-install the dvd cover and case cover. Plug the unit back in and eject and close the cover like normal. I have never tried to remove the magnet from the cover and checked to see if the DVD player still worked correctly. I have found it easier to just leave a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Apr 09, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
I put a blank CD into the tray to record. It
If there is a tiny hole somewhere near the tray you need to poke a needle or something like that in there to open the tray.
Dec 02, 2009 | Philips CDR785 3-Disc CD Recorder
DVD disc tray will not open
Without knowing the model for the unit, it makes it a little difficult to troubleshoot, but usually the easiest way to get one of these to open up is to try resetting them. This is done on MOST DVD players by unplugging them for about 30 seconds while you hold the power button down to discharge any power that might be held in the unit, then plugging the unit back in and trying to eject it again. Keep in mind, that if the unit was moved (or even if something caused the unit to shift, like a person jumping near it) then the problem could be the dvd has become dislodged from the tray. Many dvd players will have a small hole on the front (usually below the tray) where if you insert a paper clip in about a half inch, will eject the tray part way, and then you can gently pull it out the rest of the way (making sure you do not keep pulling if you feel resistence as the dvd might have skipped out of the tray track). IF worse comes to worse and you don't have a warrenty on the unit, many dvd players can be opened by removing 1-2 screws from the left and right sides, and possibly 1-4 screws from the back of the unit (look around the edges, the screws near the ports on the back usually holds those ports in place and do not need to be removed to take the case off). Once the screws are removed you would pull back and up on the case to open the dvd player. Keep in mind, this voids a MFG warranty. Once the case is off you should be able to see the dvd and remove it unless you have a cheap dvd player which has an enclosed drive. Remove the dvd and with the case still off, plug the power in (DO NOT TOUCH ANYTHING INSIDE WHILE THE POWER IS PLUGGED IN) and try hitting the eject button on the front. IF it ejects now, you should be good to go, just put the case back on. IF it doesn't eject, then your motor is probably bad (or something is blocking the track) and it is usually safer/easier at this point to just go buy a new dvd drive.
Jul 31, 2009 | Toshiba DVR3 DVD Recorder/VCR
HT900
I kept hitting the disc exhange/eject button to turn the unit on and after a couple of tries it finally opened about half way. The whole reason i wanted to open it was to get the last dvd that i watch out of it. Well in doing so i noticed that there were some discs rattling around up underneath the cd tray (from my 1 1/2 year old). After shaking the unit a couple of times i was able to get the discs out of the underside of the disc tray. When i hit the disc exchange to close the try the unit powered up, closed the tray, and operated fine and i am back to using it like i used to with out any other problems.
Oct 15, 2008 | Panasonic SC-HT940 System
Disk player door
You would need to disassemble the unit to take out both the CDs. Trying to force the disk out without opening the unit might damage it. If you are not comfortable with open it, please get someone who can actually do it for you. please revert back with the results.
Mar 22, 2007 | Bose (321GS) System
Sony Handycam CCD-TRV608 Camcorder Logo
144 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
