Question about Ariston Technologies AW125NA 13 lbs. Load Capacity Washer
Ariston Aml 125 wil not start...2 leds flashing...
Hi
My ariston washer/dryer Aml125 will not start. 2 leds flashing, water goes into the machine and pumpen pump water ud from mashine.
Please help....
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: My Ariston AML 125 dosen't
Hi.
If the water is cold, check the inlet hose and the hot inlet in the dual inlet valve connected to the hose. If there is no hot water the cycle will not progress, and that may be related to the drain problem.
If the machine does not drain even with hot water, check the thermostat and the pressure switch. The thermostat decides when to open and close the hot inlet, moving forward with cycle when temperature is met. The pressure switch determines among other things when to start and stop drain pump.
The thermostat is tested reading Ohms, multimeter set on impedance must read low or no impedance at room temperature on thermistor contacts. The pressure switch is replaced if there is a drain problem and the rest does not help. This part is more difficult to test.
About the drain problem, check first drain lines, drain well and drain ose at the back.
As first thing call Ariston at the number listed on the owners manual and check warranty status.
Posted on Sep 15, 2010
taran_2005
  • 10515 Answers
SOURCE: looking for user manual for
You could download the manual from :-
http://safemanuals.com/user-guide-instructions-owner-manual/HOTPOINT-ARISTON/AML%20125-_M
Click on download the complete user guide. It would direct you to a new page.Rate the questions.Once done, a link for ' download ' would appear. Save the manual on the desktop.You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 21, 2011
I have an ariston washer dryer combo. today I turned it on to do a wash cycle. the knob no longer clicks or shows the times of other cycles. I've turned it off and on a few times but nothing helps
Ariston armf 125 washer dryer combo - YouTube
? 4:14
www.youtube.com/watch?v=zPtG5Q3qQ3Q
Oct 23, 2010 - Uploaded by troykm Rinse cycle. Correction - it does do 3 rinse cycles!! :-)
[PDF]Instruction Manual - Ariston Appliances
aristonbrand.com/media/WDG-8629-User-Manual-19510586801_AU.pdf
WASHER-DRYER ! This symbol reminds you to read this instruction manual. ... from its packaging. 2. Make sure that the washer-dryer has not been damaged.
Sep 22, 2015 | Washing Machines
The ariston washing 125 show h2o on the scrim
The washing machine fails to load water (The wording H20 is displayed).
  • The water inlet hose is not connected to the tap.
  • The hose is bent.
  • The water tap is not turned on.
  • There is a water shortage.
  • The water pressure is insufficient.
  • The START/RESET button has not been pressed.
Dado
May 29, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
Where can i download instructions in english for a Ariston ARML125
HI JENIFER, I FIND A SOLUTION FOR YOUR QUERY. THE MANUAL FOR ARISTON ARML 125 IN ENGLISH IS AVAILABLE AT www.cintelcorp.net/ariston-aml-125-manual
Nov 03, 2011 | Washing Machines
Hi there, i have just moved into a flat and there is the ariston aml 125 washing and dryer and ihave no idea how to use it. all the soap powder sold in nz is top loader soap powder, is this ok to use in a...
Enter this URL into your web browser and you will be able to download the full manual.
http://safemanuals.com/314159.php?k=3c09a0dae46be7bd02298add3193e78a&ID=433640&q=HOTPOINT-ARISTON%20AML%20125
Jan 26, 2011 | Washing Machines
Looking for user manual for ariston AML 125 in english
Hope i helped you.
Jan 21, 2011 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
Jun 26, 2008 | Washing Machines
How do I translate the manual?!?
hi i have this machine ,when you open the draw on the left hand side ,the detergent goes in the largest section ,fabric softner in the mesh one ,pre wash (bleach etc in other one)now for washing just use cycles 1,2.3,or 4 one being the longest cycle 4 being shortest middle knob is temp, last knob is dryer, if you want it to dry automatically after a load of washing put it on the iron or other to window looking symbols ,otherwise if not drying have it on 0.i would send u a manual but i've lost mine hence why i'm on his site at all.Hope this helps get u started.
Jan 24, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
Sep 07, 2007 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
440 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
