FixYa.com
Tags:
Compaq Deskpro heatsink fan
CPU fan question
By Bouncy - usenet poster
I've just upgrade a slot one compaq deskpro using a FC 370 pin convertor and
a pentium III 550 FC processor . The problem being that the compaq has no
connector on the motherboard for a CPU fan .Anyone know if it is possible to
get a convertor that will convert a standard HDD power connector so it will
connect to the fan supplied with the CPU .The only other way I can think of
curing this problem is to run a socket 7 CPU fan on the chip ,but the socket
7 is physically smaller in size and the fans you can buy seem to be exact
size for the CPU (I'm worried that as all the CPU is not covered it might
get a bit warm!!!). If you've never heard of a convertor has anyone got any
Idea's where I can get a good enough socket 7 fan that will be sufficient in
doing the job (bear in mind that I live in the U.K.)
Thanks in advance
Michael
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 28, 2006
Not Rated (0)
kcw573
kcw573 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
(Alwin Chi Ho NGAI) wrote:
[snip]
>... can't remember off the top of my
>head whether red or yellow is +12V
Yellow is +12 Volts - on a PC... Orange on some Compaq's... ;)
__ __
//)) //))| Richard RUDEK. MicroDek. Chatswood, Sydney. Australia. |
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Horner
Horner - usenet poster
Rating: 0%, 0 votes
>connector on the motherboard for a CPU fan.
Have you checked that the CPU converter doesn't have the Fan power connector
on it - probably three terminal (+12, Ground/Zero volts and tacho/fan
rotation)?
>...Anyone know if it is possible to
>connect to the fan supplied with the CPU.
Yeah, I would normally make one if needed, but a quick look through
Australian Personal Computer brings up # (prices look high), so
take a look though the mags, or try #.
>...The only other way I can think of
>get a bit warm!!!).
Yeah should work, as only the central portion of the CPU chip is thermally
attached to the heatsink. I've not tried to use a socket7 heatsink with an
S370, so I would try to use the P3's heatsink/fan, then see if I can replace
it's fan with another type of fan with the correct power connector, then
that should be fine. Just make sure it uses a ball bearing, and not a sleeve
one. Otherwise, I'd get the right power cable for the P3 fan.
>...If you've never heard of a convertor has anyone got any
Ah, now you say. Well I live in Australia, (aus.*) so I can't help with
suppliers.
__ __
Solution #3
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
Yes you can get connectors like that. I am thinking you want the 3 pin
fan connector to a 4pin molex??
I'm sorry i dont know of any stores that have them, but i have seen
them at computer swap meets for around $3.
- Hide quoted text -- Show quoted text -
> >Thanks in advance
Solution #4
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
Yes there are converters. You can make one yourself.
> Thanks in advance
> Michael
Peter Le
Powered by Microsoft Backoffice
PC Systems ?? 1999
Solution #5
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
"michael fenton" <> writes:
>Thanks in advance
>Michael
Haven't seen a converter like that myself either, but you can easily
construct one yourself.
The black wire on a HDD connector is 0V, can't remember off the top of my
head whether red or yellow is +12V, but you can easily tell with a
multimeter. Pop into your local electronics store to find a suitable
plug, wire it up and that's it.
You can get header pins and solder it onto the end of the wires if you
want a removable connection. Wrap a bit of tape once it's plugged it to
keep it secure.
The red wire of the fan goes to +12V, black goes to 0V and if there's a
third one, its for monitoring fan speed and can be left unconnected.
If you don't mind cutting the end of the fan connector, I suggest
soldering the wire of the fan and the wires coming out of your plug
directly.
If you have a socket 7 fan with power connections, you can cut the wirings
off and join that up with your bigger fan.
Alwin
Alwin Ngai
5th yr BSc(Hons)/LLB
University of Melbourne
Can you Help with these System Cooling problems?
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
System Cooling
Warning light.
Electronic fault indicator... Answer This...
System Cooling
Peoplesoft
There are how many ways for... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
