Question about Lands Phones
My se150 after 5/6 rings a female voice tells people who call you cannot leave a message try again later i do not hae an answer machine please help jack 01241 870263
sandrew
  • 2961 Answers
SOURCE: Lost manual--
See if your phones manual is here, if not probably similair instructions https://www.bellsouth.com/apps/nlss/index.jsp
Posted on Oct 31, 2006
SOURCE: Memory Full?
I unplugged my power supply cord from back of phone and replug it again, I found there were in fact four messages. After I deleted them I was able to use the memo button again. So perhaps this willhelp you, too. Ackey320
Posted on Sep 02, 2007
SOURCE: GE 29893GE1-B Digital Answerer Problem
G.E.speaker phone model#29322GE1-a how to program other numbers in phone
Posted on May 17, 2008
SOURCE: Reset the answering machine without the manual
GE 28112EE2 1.9 GHz Twin Cordless Phone
Flashing CL.
Lost Manual.
Can you help.
Posted on Jun 23, 2008
  • 95 Answers
SOURCE: need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:http://www.trianglecables.com/tellinsplitl.html
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Posted on Mar 29, 2009
My answer phone messages have all been deleted. When someone rings the phone, the answer phone tells callers that they cannot leave a message, please call back later.
no phone stated.
is this and old relic answering machine
or old land line portable home hands-free phone system?
what is the name if the phone and model.#
then helpers can help.
i moved you to phones
Feb 24, 2016 | Cell Phones
Why won't the answering machine, when set to 'answer on' not record a message?.It goes to voice mail. Is my machine defective?
Maybe the answering machine is set to pick up at say"5 rings" and the voice mail is set to pickup at "4 rings" . Change the voicemail setting to a higher setting than the answering machine. That may be the problem.
Aug 26, 2014 | Lands Phones
A man answers my phone with "The answering machine is off. Please leave a message" Sometimes it leaves a message and sometimes it doesn't. The menu options I get will not restore it to my...
"The answering machine is off. Please leave a message" (sic) This doesn't make sense.... how can one leave a message if the answering machine is OFF! Unless it goes to a voicemail etc? It's just not possible?
I suggest that you use your manual, and reset up your system again, perform a Factory Reset and then set up what you need to do again, this will clear any erroneous data that maybe causing any problems.
Whats seems to be happening is that the default "Voice" is being activated instead of the recorded message? I think you need to do it again.
After you have done this, record your message and set the answering machine to ON. Then test it from another phone.
NOTE sometimes with answering machines, if they ring more than a certain number of times, without being answered, the AP may switch OFF, ON or indeed do "Other" functions" that may be assigned, so ensure that this "Feature' isn't active or enabled or whatever.
May 16, 2011 | Uniden Cordless Phone
Instead of going to my message the phone rings out and and goes to voice saying sorry we can not take your message please try again later
It may be similar to the problem I had with the wireless home phone with answering machine not taking messages when had the answering machine set to 12 rings before answering. Found the sim card (my wireless system) auto response would answer first. Fixed it by reducing time to 6 rings and answering machine now comes on first. This might resolve it for you.
Oct 17, 2010 | Uniden Cordless Phone
When someone calls me the ringer on the phone does not ring.I do not know how to turn the ringer back on. Also when someone tries to leave me a message the answering machine does not record the message....
On the phone not ringing, just push the volume up button while the phone is not in use, that should adjust the ringer volume. As for the message saying that calls are being routed to an automatic message sertvice, that sounds like a voice mail offering from your service provider, not the phone. Uniden phones have a default greeting that says "Hello, no one is availible to take your call, please leave a message after the tone" Contact your service provider and find out if you have voice mail service on your line. If you do and want to use the answering machine on your phone, you will need the service provider to allow for more rings before the voice mail service takes the call.
Mar 16, 2009 | Uniden 5.8GHz Dual Cordless Phone
1188 answering machine
I have model no. 1188 bellsouth digital answering machine. If you have to leave a message, the message I recorded is no longer there, there is a generic message saying please record your message. How do I go back and record my voice with my message. I cannot find my original manual.
Oct 07, 2008 | BellSouth Digital Answering System 2006C...
Instruction Manual
GE Digital Messaging System ~ Voice/Time/Day stamp
1a] press and hold down STOP/set button and wait for promps.....
ie. press NEXT to change Day stamp and then SET to pick.
ie. press NEXT to change Hour and SET to pick.
ie. press NEXT to change Minute and SET to pick.
1b] press NEXT to pick 1minute allowance recording for recieving messages coming in, or 2 minutes or 3 minutes or 4 minutes. This machine only has 1/2 hour of recording time, so maybe you can 'tell' -record- that and let incoming callers know they have only minutes and machine will automatically shut off and cut them off [hang-up] on them.
2] press and hold down Greeting button and follow promps to change the answering machine voice promps to your own voice. Machine will automatically PLAY BACK your voice, if you don't like what you hear, press and hold down Greeting button again and try again.
~ hope all above helps.
May 10, 2008 | GE 29888GE1 Digital Answering Machine
Lands Phones Logo
90 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
