Question about Microsoft Windows Server Standard 2003 for PC
Ntbackup causing server to crash and reboot
Running windows 2003 server standard edition and using ntbackup to Dat tape.
Have problem with backing up the whole system.
I can run a small back up of a few files to the tape drive with no problems,
but when I try and backup 30/40Gb the process runs for 15/20 minutes and then causes the server to reboot.
I have loaded all the latest drivers for the tape drive and the latest service packs.
Help please.
The
  • 61 Answers
Try to monitor the memmory and processor usage in task manager  performance tab.Check you have sufficient memmory sixe in your server.
Posted on Oct 27, 2008
Hi , We are having 2 windows servers with identical configuration, and also we are using the windows 2003 with vendor application, We installed 8 GB of RAM in both server , But I could only 4 GB amount...
Hi
To reply your query in short. If you have any of the following versions of server it would support the maximum RAM upto 4 GB.
Windows Server 2003 R2 Standard Edition
Windows Server 2003, Standard Edition SP1
Windows Server 2003, Standard Edition SP2
Windows Storage Server 2003
Windows Small Business Server 2003
If you are using : Windows Server 2003, Web Edition
It will support only 2 GB of RAM
For your information to get a complete information about Memory Limits for Windows Releases. Please visit the following site:
(msdn.microsoft.com/en-gb/library/aa366778.aspx)
If you find it useful please do not forget to rate this solution.
Jul 14, 2010 | Microsoft Windows Server 2003 Enterprise...
I have a scheduled task set up to do a backup of a specific file. It is on the domain and it will run but it stops too quickly as the backup file has not been backed up for a while. It will not produce an...
Check whether the back up service is running properly or not. Once restart the Help and Support service in Services menu which can be accessed by running services.msc in Run Tab.
Oct 26, 2009 | Microsoft Windows Server Standard 2003 for...
DDS-5 not compatible with windows 2008
I am pretty sure that the driver should be compatible with win08.
If you are using backup exec then try switching to use symantec drivers for your tape drive (setting withing BUEX)
If it is just the tape that cant be read or identified and was backed up using windows backup then try restoring the backup on a 2003 server and then copying the data across the network.
May 10, 2009 | HP 364446-001 Storageworks DAT 72x6 DDS-5...
Backup software for certance travan 40?
You will have to load a driver for the Travan drive, if windows server 2000 sees the tap drive you could use NTbackup.exe to configure a back-up here is a link to read more about it. http://support.microsoft.com/kb/237310/
Good Luck
Jan 28, 2009 | Certance Travan 40 GB (stt3401a-sst)...
Exchange server
Please click on the link mentioned below:
http://www.msexchange.org/tutorials/Exchange-2003-Backup-Restore-NTBACKUP.html
Thanks
Jul 30, 2008 | Microsoft Windows Server Standard 2003 for...
Window 2003 AD NTBackup Problem
Reboot into Directory Services Restore Mode (F8 at startup) and use NTDSUTIL
to check the integrity of your database. Usually, an offline defrag will
fix this kind of error. If it doesn't, and the integrity checks fail,
you'll need to try and repair. Note that there could be issues with the
repair so be prepared to restore from backup.
Google NTDSUTIL for the syntax. There's loads of info. on TechNet2.
Feb 01, 2008 | Microsoft Windows Server Standard 2003 for...
Active directory
you can use in built ntbackup utility.
In a DC, in the Items to backup window, expand Mycomputer and you can see System state. select that and proceed. It will take the Active Directory data.
Nov 06, 2007 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
197 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
