Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool toploader gearbox/clutch removal
I need instructions on how to remove / replace clutch assy. on whirlpool toploader machine can you point me in right direction.
Thanks
Peter Bradshaw
pbradshaw6@hotmail.co.uk
  • pbradshaw6 Oct 19, 2008
    The machine fills and pumps out ok but agitation and spin do not work I have checked the drive coupling and it is intact the machine just makes a clicking noise when trying to spin or agitate
  • julian-peck Mar 14, 2009
    I have turned Whirpool on its front and have removed motor and pump but I do not see how to remove the gear box.
    Anyone point me in the correct direction?
    Thank you.
    Julian (jhapeck@gmail.com)
Last Night I took the machine apart to find clutch/brake assy ok gearbox was also ok then I noticed shaft coupling was different than new part I had in stock, new part made totally of nylon, old part fitted to machine has steel insert built into nylon. this was not fully located onto motor shaft and the first 1/4" of motor shaft had been stripped back to round ( no flat faces) also inside the steel lined bore of the nylon coupling had been worn to round.I replaced with new coupling of nylon and ensured both nylon parts fully pushed home onto motor shaft and gearbox shaft with any freeplay / gap being allowed in the rubber drive link. This has worked for now but expect trouble in future with worn motor shaft.
Posted on Oct 21, 2008
Cleaning instruction for a whirlpool toploader
IF IT SMELLS MOLDEY OR IS STAINED,JUST ADD A CUP OF NEAT BLEACH,AND RUN ,THE 90c PROGRAM,THANKS
Jul 17, 2014 | Whirlpool Washing Machines
Clutch instructions
Hi thereTo remove the clutch assy you can either take out the engine or engine and gearbox togeather/or remove tailshaft and x member gear stick THEN jack up on high stands and lower down the gearbox as far as poss but then check engine for parts hitting like heater /pipes wire hoses ect,ect,ect
So taking the lot out is the best and also for refitting the g/box but its a bugger of a job.
Have a goodday
Apr 08, 2014 | 1967 Austin-Healey 3000
What size bolt is it to remove the agitator from a whirlpool rope
7/16 bolt holds the agitator onto the shaft of transmission
Feb 09, 2009 | Whirlpool Washing Machines
How to replace the gear case for whirlpool washer lsn1000kq0
remove 2 screws on rear of console lift console forward and roll back remove the lid switch connector remove the 2 clips on each side pull rear of cabinet forwardand slide cabinet off remove screws in center of agitator under cap and pull off ..lean washer backward remove pump clips and hoses remove 2 screws in motor clamps remove clamps and motor remove 3 1/2 in bolts holding gearcase to bottom slide gearcase out remove clutch and reinstall on new gearcase if you go slow and take note reassembly not that hard
Nov 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
WHIRLPOOL TOPLOAD WASHER LSR7233EZO
hithe part you need to replace is called a drive coupling which goes between the motor &transmission you have to remove the cabinet to get to this part if you tip the washer towards the wall and look between motor ant transmission to remove the cabinet 2 screws at the console where cabinet meet lift console 2 brass clips 1 each side spring clips screw driver in cavety and pry remove cabinet 2 clips on pump remoce 2 screws on motor remove 2 long metal clips on motor disconnect wiring from motor remove 2clips from remove motor replace coupling thanks the appliance dod
Sep 17, 2008 | Washing Machines
How do I replace the belt on a whirlpool washer? I have the belt. Oh, You charge for this. I thought it was free. Silly me. Never mind.
if it,s a belt drive whirpool it's at least 22 yrs old ..if you never done one it can be tricky..1st remove back ..remove brace on rear and the other 2 from bottom remove the 1 bolt in transmission that has a spacer lossen the other 2 but DO NOT REMOVE.belt will need to be worked up throyugh where the spacer was removed and between where clutch spring is ..woops!! remove springpush up clutch bracket work belt over pin ..ck parts bag there are usually instructions and picture if the part is a whirpool 95405 belt hope this helps some
May 20, 2008 | Whirlpool Washing Machines
Replacing lid switch for whirlpool washer LSR5132JQ0
U WILL NEED TWO TOOLS TO DO THIS JOB.A PHILLIPS AND A FLAT SCREW DRIVER.YOU NEED TO OPEN THE LID AND REMOVE THE TWO SCREWS THAT ARE LOCATED ON EITHER SIDE OF THE LID SWITCH OPENING.YOU THEN NEED TO LOCATE THE TWO SCREWS THAT HOLD THE CONTROL PANEL DOWN.ON THE SOUTH AFRICAN VERSIONS OF THE WHIRLPOOL TOPLOADER THEY ARE IN THE FRONT OF THE CONTROL PANEL WERE ITS VISIBLE ENOUGH TO YOU.REMOVE THEM AND LIFT THE CONTROL PANEL UP AND BACK.YOU WILL NOTICE TO CLIPS ON EITHER END OF THE TOP REMOVE THEM WITH A FLAT SCREW DRIVER ALSO REMOVE THE WIRE LUG ON THE RIGHT SIDE.YOU WILL THEN NEED TO REMOVE THE CABINET BY OPENING THE LID AND PULLING IT TOWARDS YOU IN A SLIGHT UPWARD POSITION.NOW THE DOOR SWITCH IS LOCATED ON THE CABNIT IT SHOULD BE SMOOTH SAILING THEREAFTER.TO PUT THE MACHINE BACK ITS THE SAME WAY YOU REMOVED IT.AS FAR AS A PICTURE THERE IS NOT MUCH AVAILABLE.GOODLUCK.MOHAMED
Oct 07, 2007 | Whirlpool LSR5132J Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,202 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
