Question about Dryers
Whirlpool duet dryer shuts off and E1 code shows
  • annlfc Mar 18, 2009
    my whirlpool Gold drywr keeps showing E1
  • 1,031 Answers
E1 is an open thermistor. The thermistor lives on top of the blower housing. Get to it by removing the bottom quarter panel.Does the E1 error represent failure of the thermistor,
The quarter panel is right there in front, down at the bottom, below the door. Look closely and you'll see two screws. Remove them and the panel comes right off. Some pics at this link:
http://fixitnow.com/2005/03/appliance-repair-revelation-peek.htm
hope this helps.thanks and Godbless .appreciate by rating as fixyaa
Posted on Oct 17, 2008
I have error codes E1 and F9 on my whirlpool duet washer
Duet washers use F/XX codes. I couldn't find E1 but the F/09 code is set by an overflow. To eliminate the code:
- Check for clogged/kinked drain hose
- Check wire harness connectors for pump, pressure switch, and CCU
- Check/clean pump filter
- Check inlet valve for complete shut off
- Check for pump failure
- Check pressure switch operation
Dec 13, 2016 | Whirlpool Washing Machines
Error code E1 what does it mean
The problem is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in troubleshooting this error code.
Troubleshooting Error Code E1 on Whirlpool Duet and Kenmore Elite Dryers
Aug 27, 2011 | Kenmore 62602 Electric Dryer
The dryer shuts off, keep getting an E1 code, what needs to be done
It sounds like this is a Whirlpool Duet or a Kenmore Elite Dryer due to the error code E1 being available only on this models. The problem here is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in accessing the thermistor.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Measure the resistance of the thermistor and refer the table below. Normal thermistor resistance is around 10000 ohms (10K) at room temperature.
Replace the thermistor if the resistance is significantly higher (or lower) than what it is supposed to be based on the resistance table above. Check the wire harness connecting it to the control board, if the resistance turns out good, and make sure the connectors are good and the wires are intact. Replace the wire harness if necessary. Consider replacing the control board if both the thermistor and the wire harness turn out good. The link below might enlighten you further on the troubleshooting of the thermistor.
Thermistor Troubleshooting on Whirlpool Duet and Kenmore Elite Dryers
Aug 21, 2011 | Dryers
Kenmore ht3 dryer, the dryer runs for about a min. then shuts off. the code E1 comes up. i have clean the vent out from within the the dryer. is their a sensor that shuts it off or what.
The error code E1 indicates that the thermistors is open or having a very high resistance. Click on the link below for the detailed troubleshooting of the thermistor.
Whirlpool Duet and Kenmore Elite Dryers Thermistor Troubleshooting
Jul 19, 2011 | Dryers
I get an E1 code on a whirlpool duet dryer. What could the problem be.
The problem is the control thermistor being detected open by the electronic control. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Click on the link below for the detailed troubleshooting procedure.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Feb 04, 2011 | Whirlpool GEW9250 Electric Dryer
A code E1 flashes the dryer shuts off and the clothes are still wet
The fault code E1 means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values.
Oct 25, 2010 | Kenmore HE5
Duet error code e1
Whirlpool Duet E1 Error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 02, 2010 | Whirlpool GGW9200L Gas Dryer
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Aug 05, 2008 | Dryers
Whirlpool Duet Electric Dryer (5yrs old)
An E1 Code is a thermistor fault TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
607 people viewed this question
Top Dryers Experts
