Question about Sony Handycam DCR-TRV340 Digital Camcorder
Lodged memory card
How do I retrieve an incorrect memory card which is lodged inside my camera?
  • bkviva Nov 20, 2008
    Thank you so much! After much poking and probing, my husband and I tried your suggestion using crazy glue gel and a popsicle stick cut straight. It worked perfectly and there appears to be no damage to my camera or the errant memory card either.
    Scholar:
  • 74 Answers
If you cannot take apart the housing to remove the card here is one technique I have used that requires a steady hand. Provided the end of the card is visible but not exposed enough to be able to grab it with small tweezers, using a small piece of wire or paper clip, bend the end so that a small part will lay flat against the exposed end of the card. With extreme care, place a very small amount of quick-curing epoxy on the bent end of the wire and place it against the card and hold in place until hardened. Be VERY careful not to use too much glue or you may wind up gluing the card in place. If luck is in your favor you can use the wire to pull the card out when the epoxy hardens.
Best of luck, may the force be with you.
Posted on Oct 17, 2008
Printer won't take paper, crinkles paper and shuts down
that happened to me once and upon close inspection I found a staple lodged in it...check for anything lodged inside
Nov 04, 2011 | Canon PIXMA iP1600 Printer
Tip
Troubleshoot Non-Retracting Lens Due to Camera Drop
<span>Remove the batteries from your digital camera and leave them out for a few minutes. If you are using rechargeable batteries, make sure the batteries have a full charge before placing them back into the digital camera. It is recommended that you charge the batteries for at least 6 hours. If you are using regular AA or AAA batteries, make sure you are using brand new batteries of the same brand. Turn the camera back on to see if the lens will retract. If that doesn't work, turn the camera back off and try turning it back on while you are pressing the function or OK button.<br />If the batteries were low when the camera was dropped, the lens may not retract properly until the camera is reset. Remove the memory card from your digital camera and install new batteries. Do not put the memory card back into the digital camera and turn the digital camera back on. You will get an error message regarding the memory card, but that is okay. With some digital cameras, leaving the memory card out will trigger a reset within the digital camera.<br /></span><span>If you have an audio/video cable (AV), insert that cable into the digital camera and turn it on. By using an AV cable, the LCD screen will not power on, which means there will be more battery power available to the digital camera. If any dirt got into the digital camera when you dropped it, the extra power may help the camera retract the lens.</span> <span>Place your digital camera on its back on a hard surface. The lens should be pointed towards the ceiling. While pressing the shutter button, turn the digital camera on. The idea behind this concept is that the camera will try to autofocus, which may help seat the lens barrel pins back into their slot.<br /><b><br /></b><br />It is possible that when you dropped your digital camera, dirt, sand particles, etc. may have lodged themselves into the lens barrel. Gently blow around the lens barrel to knock lose any particles. Using a microfiber cloth, wipe off the lens and try to wipe as deep into the lens barrel as you can. You can also try using compressed air and blowing it in the gaps around the lens barrel. Be careful not to blow any of the compressed air onto the lens itself, as the pressure of the air may damage your lens. The idea here is that if there are any particles lodged in the lens barrel by the lens mechanism, you will be able to knock them lose.<br /></span>
on Jun 29, 2011 | Cameras
Bathing suit lodged inside dryer vent chamber
Without actually seeing exactly where the item of clothing is lodged, this will be a tough problem to resolve. However, as a guess I will suggest the following:
Carefully pull your dryer away from the wall, far enough so you can get behind it. Be carefull not to stretch, pinch or damage your gas line. Next, with a screwdriver, unscrew the large vent clamp that attaches the aluminum vent to your dryer. Pull this vent pipe off the dryer inlet and see if you can access the lodged item. If not, you may have to attack the problem from within the dryer.
Feb 21, 2011 | LG DLG5988 Gas Dryer
Keeps making holes in clothes
Carefully run your hand around the inside of the washing drum to check for catches or damage, perhaps a screw or similar that has lodged in the drain holes of the drum. Remove the agitator, if applicable, and check for foreign object(s) lodged underneath.
Mar 19, 2010 | Washing Machines
I dropped my psp while i was playing a game and now, when i play that particular game it hangs. i tried playing the other games saved in my memory card and they all work perfectly well i tried to reformat...
If you purchased the game from the PSN redownload it....If you are using a UMD then inspect the casing for the disc and make sure there isnt a piece of plastic broken on the casing, I had a game that had a piece of plastic that had broken off and lodged itself inside the casing and when I played it it scratched the disc so bad it wouldnt work
Sep 30, 2009 | Sony PlayStation Portable (PSP) Console
Memory card full but computer cant read it
Maybe the pins in the memory card are broken or there may be dust lodged in the memory card :D
Dec 08, 2008 | SanDisk 2GB microSD Memory Card
Retrieval of Pictures taken without a memory card
If you remove memory card your camera will show the pictures held in his internal 27 megs memory, as if it was memory card. Same if you connect to computer with no memory card inside.
This is all.
Apr 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Gamecube games lodged in Wii
Only one disk can fit inside a Nintendo wii so possibly your game cube game got stolen
Feb 24, 2008 | Nintendo Wii Console
Sony Handycam DCR-TRV340 Digital Camcorder Logo
51 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
