Question about Asrock 939Dual-SATA2 Motherboard
On POST Computer Beeps
Hi, I have a 939Dual-SATA2 and sometimes when i turn on the pc the computer beeps several times and won't POST.
I thought it was VGA card problem so I replaced it, but it's the same. Sometimes beeps sometimes work perfectly!
Any ideas? It's very annoying
    Problem Solver:
  • 10 Answers
Put your memmory freq lower in the bios settings they are set to high for your type of memmory thats why it beeps or does not show boot post screen.
Posted on Oct 17, 2008
Why does my computer light come on but want boot and want show a screen and making a beeping sound
In simple terms, you have a hardware failure, probably in your motherboard, hard drive or memory.
The beeps your hearing, are there for a reason. The way it works, is, when you first turn a computer on, it goes through a "Power-on, self test", (know as a POST).
During this period, the BIOS queries the system hardware, such as the hard drive controller, the i/o ports, the memory, etc. and expects to receive back a specific return code which indicates that the specific hardware is running properly.
If it finds a failure in some element of the hardware, it will issue a specific pattern of beeps to tell you which part of the system is failing. (It does this because the system may be unable to display the error on the screen).
Each of the different BIOS manufacturers (BIOS is an acronym for "basic input output system, the hardwired code that talks to the actual hardware), have their own series of short and long beeps, for the different type of failures. So to know where the failure is, you must first know what BIOS manufacture you have in your computer.
Some of the more popular manufacturers are: AMI, Award, IBM, Phoenix, Macintosh, etc.
When you first turn on our computer, the display will report which brand of BIOS you have, and its version.
Once you determine the brand, you can go to any number of web pages that have a cross-reference for the beeps for each brand on BIOS.
I think most adhere to the old IBM PC beep codes as follows:
No beeps: no power, bad CPU,
1 beep: normal
2 beeps: POST/CMOS error
1 long beep, 1-short beep: motherboard problem
1 long beep, 2-short beeps: video problem
1 long beep, 3-short beeps: video problem
3 long beeps: keyboard error
Several long beeps: memory failure (most common fault)
Continuous hi-lo beeps: CPU overheating
You can check with the following websites to get an idea of what's going wrong.
Computer POST and beep codes
How to Diagnose Computer Beeps eHow
Often times a SIMM has come loose in its slot (or corrosion on the connector tabs). If your getting a memory error, you can try opening the box and try re-seating each of the memory Simms to see it that might be the problem. (When you have them out, look at the row of pins along the bottom and see if any look corroded.)
Aug 25, 2014 | E-Machines eMachines Desktop PC
HP desktop computer makes many long beeps i a row and won't turn on
Those beeps are warning beeps look up what the beeps mean for your machine.
Jan 02, 2013 | HP Computers & Internet
Dell latitude windows 7 how to find out what the beep means
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains
1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
Hope this helps
Nov 27, 2012 | Dell Latitude E6520 PC Notebook
Optiplex 330, fails to POST and locks
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer.
Aug 28, 2012 | Dell Optiplex 330 Desktop Computer Pentium...
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
Hi, just swaped out a harddrive now my Mainboard *4 core Duel Sata2* does a single beep, pause then rapid beeps. can you help
Please count the number of rapid beeps. 3 short beeps is a memory error. 8 short beeps is a display memory error. 9 short beeps is a ROM Bios checksum error and 10 beeps is a CMOS shut down read/write error.
The solution will depend on the error. For a memory error, remove all of the memory sticks then reinsert each one separately and reboot the computer. If the board continues to beep 3 times, that stick is bad or the memory slot has failed.
The complete beep code list is provided here: http://www.asrock.com/support/qa/TSDQA-01.pdf .
I hope this helps.
Mar 27, 2011 | Asrock P4I45GV R5 Motherboard
Black screen when i turn on the computer
post comment in my yahoomail so thAT i can kep in touch with you!!sergio_bonjovi@yahoo.com
when you turn on the computer does the computer beeps?how many times does it beeps? when your computer beeps 3 times faster..try to check you video card!!!! but when the computer continues to beep and beep try to check the modules or the memory try to replace it with a new memory!!! but when you turn on your pc and no beep at all your motherboard will be the problem?so did i answer your questions?
Apr 25, 2009 | Compaq Presario 5000 PC Desktop
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & then repeats the p
The Cause of Problem:
The Power Buttons electrical circle sometimes just braked it by one of sensors and the result is the 2 beeps and Power Supply is in protected mode error.
The whole computer is turn off but the power button is turn on and this is the nub of the matter. Because if you want turn on the computer you can't because already turn on but just the Power button and you can't do anything.
The solution:
You need just change the Power Supply and don't do anything just the power cable put into the Power Supply after turn off computer.
Finaly change back the Power Supply.
Apr 25, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
Computer beeps, won't start up
Nope not a motherboard problem, a RAM problem, the constant beeps give it away...you may have damaged one of the sticks..try with one stick, then the other and see if it works...
Apr 20, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Oct 08, 2007 | IBM Netfinity 3500 M20 8657 Server
Asrock 939Dual-SATA2 Motherboard Logo
199 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
