Indesit WD 10 wachine machine : how to loose the drum
I just had a second hand (working perfectly) wachine machine fitted in my kitchen and I am having problem has it doesn'tdo the rinse and spinning properly. hwen i questioned the person that gave the washing machine they told me that the drum has been tighten to avoid damage durin g the transport and that I should simply loosen the drum.Is it something I can do? I don't have the money to pay for a plumber to come and was wondering if I could fix the problem...
thanks and kind regards
  • 750 Answers
There is usually a bolt on the bottom that holds the drum stable during shipping and who ever put it back on a used washer is goofy!
turn it over and you should see a big bolt
Posted on Oct 17, 2008
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
Indesit WIL143UK knocking noise
Most likely the suspension gone a bit loose. Try with lesser load
Nov 10, 2013 | Indesit W 123 Front Load Washer
Aquarius WMA40 - drum rattles. Even when empty and turned by hand, but most significantly and scarily on spin. Occasionaly bangs loudly
Disconnect the machine from the power and water supply and open the access panel on the back. You'll see a drive belt engaging onto a large wheel which is bolted to the drum. Turn the machine by hand (watch your fingers!) and check for loose parts.
If that's all OK then the the drum bearings have likely failed. The parts are relatively cheap, but unless you are an experienced mechanic it's definitely not a DIY job. Even for a pro it's a bit of a pig, as the old bearing does not come out easily and removing or refitting can ruin the outer drum. If the shaft seal is damaged the machine will leak, and whilst repairing the machine it's easy to break the cast alloy drum spider.
Customers tend not to be pleased when the job goes wrong or entails extra work for reasons beyond the control of the repairer, and professional repairers have a high chance of a non-paying recall if the machine leaks afterwards or if the new bearing didn't go in perfectly squarely. Officially the answer is to fit a complete new drum assembly which is not cheap.
On Merloni Group appliances like yours, the bearings tend to only just last the expected 5 year maximum design lifespan (4 years or less for 1200 spin speed models), and when they fail you can usually expect many other components to be worn out and waiting to fail. Replacement bearings don't last anywhere near as long, typically about 9 months to 2 years at best.
Your machine is likely about 7 years old now, so the best option is to chuck it away and buy another. Preferably not Merloni Group (Hotpoint, Cannon, Indesit, Creda) as they're all unreliable. German machines are generally very good, as are Samsung, although in recent years Bosch are no longer anywhere near as reliable as they once were, although the closely-related Siemens machines which use most of the same parts are still good as are AEG and Miele.
Merloni might be relatively cheap, but you end up buying them twice as often as machines which don't cost twice as much.
Jun 21, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Fitted a new belt to indesit is60v tumble dryer, worked for a few seconds and now does'nt work at all, just makes a buzing sound?
Check that the belt has not fallen off ...does the drum turn by hand easy if so then its fallen off .Motor could also have jammed....
Feb 10, 2011 | Dryers
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Indesit wd 12 drum
please rephrase your question as what you are explaining does'nt make sense
Feb 14, 2008 | Indesit W 123 Front Load Washer
Indesit WA105 - drum is loose and fails to spin
Hi Jezzer69 It is repairable but will take about 3 -4 hours (if you know what your doing) and the parts will cost about 65% of what a new machine will cost. You need to weigh up how old the machine is and or if its "beyond economical repair" Regards
Jul 23, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
