Question about Denon PMA-2000R 2-Channel Amplifier
Power On + red LED turns on + but final relay (click) don't come so no sound
Power On + red LED turns ON but the final relay (click) that starts the amp don't come so he stay's dead! Manual is needed for repair - it's a model from 1996-1998. Please help (GIL658@hotmail.com), thx
    Scholar:
  • 142 Answers
Your audio output transistors are shorted and your unit is staying in "protect " mode to protect your speakers from 40 to 60 volts that is being sent at them from the shorted outputs. If you can use a meter you won't need the schematic MOST likely because the outputs are USUALLY the only parts that short out. The output transistors( or chip ) are mounted to the large, finned heatsink. The #'s on the transistors start with "2SA-" and "2SC-" followed by numbers. There are two output transistors per channel. If your unit uses an IC for audio output then the # on the IC will be "STK-" followed by numbers. These parts are available from tritronicsinc.com. Good Luck!
barneyluc
Posted on Oct 17, 2008
I have a sharp television 14 inch. the problem is when i switch on the primary power switch the led turns red then pressing the secondary power the the led turns green then just about a second a click
It is self-shutting down Something electrically bad inside. Could be anything. Usually some type of overload on power supply. Need training to troubleshoot.
Nov 23, 2014 | Sharp Televison & Video
Tv not turning on
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 23, 2014 | Sharp Aquos Televison & Video
Dear Sir, I have a NEC LT 260 K Lcd projector. The lamp of the lcd was busted.I replaced it with a new lamp. After replacing the lamp the lamp is not lighting when projector is put ON, I think the...
the clicking sound hopefully is the high voltage trying to start the lamp, but for some reason there may be a connection problem between the lamp and the projector power supply.
take the lamp out.
look at the lamp and check that the 2 connecting plugs are ok.
then look inside the projector at the power sockets that connect to the lamp (when it's installed).
check that the pins are not damaged or pushed down too far to prevent the lamp plugs making a proper connection with the power sockets in the unit.
Jul 01, 2011 | NEC LT 260K Multimedia Projector
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Toshiba 36HF71 has sound but no picture
Same problem with mine. Relays click, sound, no picture and a flashing power LED. I finally found a schematic online. I went through the high voltage circuits and found the power transistor 2SC5570 was shorted out. There is also a pico fuse in that area but my was not open. I replaced the transistor and prayed the flyback transformer was not shorted. It wasn't, I'm watching my old 36" right now. Not a bad fix (17.00) bucks. Wonder what a service tech would have charged ;)
Jan 02, 2009 | Toshiba 36HF71 36" TV
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Denon PMA-2000R 2-Channel Amplifier Logo
560 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
