Continual downloading my computer keeps saying found new hardware and then downloads my hp printer - I am now on my 5th copy how can I fix this
  • 103 Answers
Boot in safe mode...
Uninstall all the previous printer versions you have got.
Install a fresh copy using the CD you were provided.
When it says found new hardware and then downloads your hp printer click cancel.
Good Luck
Posted on Oct 17, 2008
    Sergeant:
    Champion:
  • 214 Answers
Remove all the printers from the list and then install the printer again from the disc
Need software to install hplaserjet p1006
Kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,
very minute but technical tip is to
connect the printer first and insert program CD for printer in the ROM drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in next few minutes your device shall be ready to use. In case there is problem with installation with CD kindly go to manufacturers website and download windows compatible drivers.
For Safe Computing Kindly keep your antivirus updated and firewall is on.
Thanks And Regards
Kindly rate this solution
Mar 03, 2010 | HP LASERJET P1006 Printer
Can't install HP 4355 on windows 7
Installing HP 4355 on windows 7 is pretty easy ,kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,very minute but technical tip is to connect the printer first and insert program CD for printer in the rom drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in nex few minutes your device shall be ready to use.
Incase there is problem with installation with CD kindly go to manufacturers website and download windows 7 compatible drivers.
For Safe Computing Knidly keep your antivirus updated and firewall is on.
Thanks And Regards Kindly rate this solution
Feb 25, 2010 | HP Officejet 4355 All-In-One InkJet...
Cannot find my cd installer for hp deskjet d2360. trying to download for free installer. can anyone help?
If you have internet access go to hp downloads from google. If not, connect your printer to your PC (computer) turn it on. If your OS is XP the found new hardware balloon should appear above the icon on the task bar, click the balloon and the add new hardware wizard comes to the screen, read and follow prompts, as it will give you a list of some recent and current hp printer products to choose from. If the balloon as mentioned above does not appear, click start, click control panel, double click add hardware icon, and the add hardware wizard comes on screen, choose your options and follow the prompts. NOTE; if the printer has been installed on your computer previously, and your OS has not been altered (formatted) this is an easy task for the wizard, as there is a shadow copy of the necessary drivers stored in the memory of your hard drive. Hope this helps.
Jul 10, 2009 | HP Deskjet 2360 InkJet Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
May 08, 2009 | Sony Office Equipment & Supplies
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
Nov 23, 2008 | HP PSC 1610v All-in-One Printer
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
Problems in Downloading & installation of Driver 640c.
Hi Deepak,
I think you have downloaded the driver for windows XP 32 bit OS, and i think that your PC supports Windows XP 64 bit Operating System.
Click here to download the software for Windows XP 64 bit Operating System.
DOWNLOAD (x64Drv5.64.0.17.exe)
Installation Instructions: USB Connection
1. Download the x64Drv5.64.0.17.exe file.
2. Once downloaded, choose Open or just run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below.
Note: There may be a long pause between each of the steps below.
4. Choose Direct Connect.
5. Power on the printer, and connect it to the computer when prompted.
6. The "Found New Hardware Wizard" will be displayed.
7. Select No, not this time.
8. Select Install the software automatically (Recommended).
9. Depending on your product, you might see one or more Windows' warning screens.
10. Click Continue anyway or Yes each time these Windows warning screens appear.
11. Click Finish.
12. Reboot your computer (Highly Recommended).
Installation instructions: Wired and Wireless Network
2. Once downloaded, choose Open or just Run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below:
4. Choose Network.
5. Choose your printer after the installer has identified it on the network.
11. Click Finish.
Thanks
Rizz
Jul 26, 2008 | HP DeskJet 640c InkJet Printer
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn’t work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click “Print Spooler”. Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you’re lucky, this might be all you have to do. Still doesn’t work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer’s software from the manufacturer and reinstall it. get more information for printer spooler error .Hope this helps you.
Mar 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
jasbo
jasbo
