Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Picture does not appear on switcing on the camcorder
DV-136ZB can't take pictures to my computer.
Are you trying to transfer videos from your camcorder to the computer, or use the camcorder to create pictures directly on the computer ?
Jul 26, 2017 | Global New Beginnings DV-136ZB Camcorder
No picture on LCD screen
Flex wire connecting LCD to the camcorder is broken. I bought it in the repair shop and did it by miself. it's very common problem
Good luck
Meggita
Aug 25, 2009 | Samsung Compact MiniDV Digital Camcorder
CCD-TR705e Sony video recorder hi 8 playback 3 beams
the camcorder flickers when viewing playback - pictures flickering
Dec 10, 2008 | Pure Digital Point and Shoot Video...
Sony camcorder DCR 265E
i think you are in picture mode when the screen mode is changed then it will appear black and recording cannot be done beeing in that mode you have to change the screen mode into recording mode and then continue
May 25, 2008 | E.Digital Sony DCR-TRV265E camcorder Pal
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Camcorder problems
dear sir, Please check with by playing pre-recorded cassatte in the camera( that if you know the recorded picture is good. thank u. reply me.
Jan 12, 2007 | JVC GR-SX24 S-VHS-C Analog Camcorder
Red lines on screen when recording
Important Notice
Digital 3CCD Camcorder
Panasonic has discovered a premature component failure with a limited number of PV-DV953 (2003 Model) and PV-GS200 (2004 Model) 3CCD camcorders, which may cause an abnormal camera picture (incorrect color reproduction, reddish, noisy image, etc). This anomaly is limited to a specific range of serial numbers listed below.
If your camcorder demonstrates the specific symptom and falls within the serial number range, Panasonic will repair the camcorder free of charge.
Please call the following toll-free number for assistance in receiving a free repair:
Panasonic Call Center: 1-800-973-4264
Model # Serial Number Ranges
PV-DV953 (2003) E3Hxxxxxx, F3Hxxxxxx, G3Hxxxxxx, H3Hxxxxxx, I3Hxxxxxx, J3Hxxxxxx, K3Hxxxxxx, L3Hxxxxxx and A4Hxxxxxx
PV-GS200 (2004) C4Hxxxxxx and D4Hxxxxxx
Nov 19, 2006 | Panasonic NV-GS200 Mini DV Digital...
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Using USB
Before transferring digital images through the USB Connection, you must install the driver and software that came with your camcorder. The software may vary by model. Please view the attached instructions and system requirements for installing the software. Instructions for transferring images through DVC media are provided on the disk as well. For newer models, you can use Windows Explorer to transfer still images. After installing the driver as instructed in the attachment, follow these instructions. 1. Connect one end of the USB Cable to the Camcorder. 2. Connect the other end of the USB Cable to the PC 3. Power on the Camcorder. (You will notice a green arrow appear in the lower right hand corner of your monitor indicating the device has been detected by your PC) 4. Right click the 'Start' button and choose 'Explore' 5. The Camcorder will appear as a 'Removable Disk' with a drive letter. 6. Click on the Removable Disk and two folders will appear. DCIM and SSMOV. DCIM will contain still images. (SSMOV will contain mpeg's) 7. Double Click the DCIM folder 8. Double Click the folder named 100SSDVC 9. All pictures on the memory stick will appear. 10. You can highlight any (or all) pictures you would like to transfer and move or copy to them to the folder of your choice. (You can select a folder in the left window pane of Windows Explorer and drag and drop files as well) 11. When you are through, you must 'Safely Disconnect' the camcorder by right clicking the green arrow in the lower right hand corner of your screen. (Follow the on screen instructions. Failure to do so may result in flash memory loss)
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
27 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
