Question about Lexmark Office Equipment & Supplies
I need some help! If my document holds more than one image the printer prints half of the document and sends through an error message. Any simple solution?
  • eeccleston Oct 17, 2008
    Thank you!
    Still not working: Error message reads
    Error: undefined
    Offending Command: 1
    Stack:
  • 103 Answers
I think you printer's memory has got a problem...Try reducing the size of your pictures using JPEG format.BTW what error messages are you getting. What does it say.
Posted on Oct 17, 2008
  • Hemant Ramyead
    Hemant Ramyead Oct 17, 2008
    I'm now nearly sure that the printer's memory has got a problem. Get it
    checked by a qualified person...There is I'm afraid no "simple
    solution"...
I have a brother MFC 9440CN when I try to scan a document the error message comes up as not being connected to pc. The cable is definitly connected as the print option works fine. Can you help. Thank you.
Are you scanning from the PC, or are you scanning from the printer?
If the latter, the scanner is trying to send the document to a server software on the PC, which is probably not running; hence the "not connected" message.
Try acquiring a picture using Control Panel -> Scanners -> Acquire Image and see if it works. If it does, you must run (or reinstall) the Control Center software, and configure it as to where to store the Scan-to-File documents.
Nov 02, 2009 | Brother MFC-9440CN Laser Printer
Document wont print
It could be a hardware issue.
Check first if the printer is working fine. Keep on holding down the paper button while you turn the printer on. Let go of the paper button when the power light starts to flash. if it printed out a color test pattern successfully, check if you are using the corrrect driver.
Tell me more if you need assistance in trashing and re-installing the proper driver for your printer. Include the full version of the operating system you are using too.
Goodluck.
sherlyn c.
May 23, 2009 | Epson Stylus C66 Photo InkJet Printer
Printer cacelling job half way through
Try buying a new usb printer cable, just a thought - could have a dodgy connection.... Also - try a different pusb port on your computer.
Steve
www.yourhandinmine.co.uk
Apr 23, 2009 | Epson Stylus 1400 InkJet Photo Printer
Ricoh AP2600 printer gives an error message of SC322
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Feb 10, 2009 | Ricoh Aficio AP2600 Laser Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
Hp officejet 6110xi all in one
I did a search of your product's help pages on HP.com but didn't come up with an exact match for your error message relevant to an Apple Mac OS X. Before offering suggestions, let me make sure I understand the problem.
You have a Word document open on your Mac and you want to insert an image into the document that's on the scanner.
I'm actually not clear as to whether you successfully scanned an image in the first place. If you did scan the image, where did you store it to? Have you tried scanning the image and saving it to your computer? If you can do this successfully, try inserting the image into your Word document from the location on your computer.
If you tried to scan an image and got the error message, then there is a communication problem between your Mac and the printer. Since you can print, the cable connection must be good. If the error message is suggesting that you reinstall the drivers, you can find the instructions for how to do this at the following web page at HP.com:
Installing and Uninstalling Printer Software on your Mac
You may or may not have your original software disc that came with the printer. If you don't or if you need an updated print driver, you can download that software from the following web page, assuming you are running Mac OS X:
Mac OS X Printer Software and Driver Downloads
Occasionally, you can solve errors by installing print drivers that are more recent than those you originally installed when you first got your printer. That's the benefit of downloading the latest drivers from HP.
On the off change you are using Mac OS 9, here's the relevant software download page (the version of the Mac operating system matters):
Mac OS 9 Printer Software and Driver Downloads
If all you want to do is to insert an image into a Word document, you shouldn't need Adobe Photoshop or any other expensive software application. You aren't trying to do any fancy editing of the graphic, just insert a pre-existing image into a document.
I hope some of the above suggestions help. Post back your results and good luck.
Oct 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Error Message appear when printin
It is almost two years i started using this printer but recently whenever i;m printing with this printer, i get a report; " Cam Platten Error" and my document fails to print. Please help me.
Mar 15, 2008 | Hi-Touch Imaging Technologies HiTi 730PS...
Canon imageclass MF8170c print problem
i have Image class MF 8170 c Just printing blank pages.no erro code
apear on display.
Jan 11, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
Print issue
Check and see if you put page ends in your microsoft documents. without page ends the print driver will probaly see an 81/2 by 14 inch document
Apr 19, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Printing problem
This error message indicates that the printer memory is full. You might be sending too many documents to print at the same time. I would suggest dividing the number of documents/pages into smaller groups so the printer can take the load. Hope this helps!
Feb 22, 2006 | Xerox 6100/DN Laser Printer
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
