Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
No image display
When i switch on the handy cam it does not display anything that i want to shoot
3 Suggested Answers
  • 18 Answers
SOURCE: Hi , My Sony Handy cam Model number is
for this u hv to reach the service center of sony cuz this problem is related to hardware may be the cover is not getting closed properly or any inner switch is broken etccccccccccccc
proper solution is service center
Posted on Mar 14, 2010
Rick Riggins
  • 1812 Answers
SOURCE: sony handy cam dcr-hc20 in the display top right
Error code 61:00 indicates a problem in the focus mechanism. The most likely cause for this is a lens out of place or impaired in some way. This will require disassembling camera to remove the lens block and then disassembling the lens block to repair. This can be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Oct 14, 2011
No display in viewfinder and LCD
i think you are able too see the video in play back mode. so there is no problem in your LCD.
i think the CCD has got damaged in your CAM. that is why you are not able to view anything in shooting mode.
because CCD is the layer which converts the light falling on it to a electrical signal and shows us as a complete image.
Dec 25, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
IN SONY HANDY CAM HDD XR150 - LCD SCREEN THE SOME COLOR LINES ARE DISPLAYING INSTEAD OF PICTURE . THE PROBLEM OCCURRED AFTER REMOVING THE HANDY CAM FROM THE TV SET AS PLACED IT OVER 30MIN.
You need a new sony display flex cable installed in your camera.. it is a rather simple procedure.. dont let anyone tell you it is going to cost 300-500.00 to fix. the cable or flex that makes the display viewable is called a LCD display Flex. If you don't get any image on your display, the image has lines, display has no backlight or anything like that, replacing this flex cable should fix the problem.
you can buy the flex cable on ebay for less than 30.00 and the fix is rather simple.. the display has the flex cable on the back side and there are 3 screws that holds the display on the camera body. when you take them out of the camera using a PH00 small screw driver, you can then take the flex cable out of the display and easily replace.. it doesnt take rocket science to take these out and replace them.. good luck.. remember... you can buy the flex cable that makes the display viewable and then when it is replaced you will then be back in business with your camera.. good day....David...Mt Holly, NC
Jul 29, 2011 | Sony Handycam DCR-SR300 Camcorder
My cam can't display any image before and after shooting
Having gone over a month with no response, I assume this is no longer a problem.
Jun 13, 2010 | Cameras
Hi , My Sony Handy cam Model number is :DCR-DVD105. When i try to shoot any thing after i switch on my handy cam i get the error " DISC COVER OPEN,ACCIDENTLY TRUN ON POWER AGAIN" Every time i switch off...
Mar 14, 2010 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony handy cam n50
Sony video camera serial No 1336920 N50 software needed
Jan 21, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Sony DVD92 LCD/Viewfinder doesn't display image
I had this problem and called Sony. Apparently there was a problem with handy cams and they paid to fix it.
Dec 17, 2007 | Video Cameras
Canon eos digital canon rebel xti - LCD won't work when shooting
Most DSLR cameras (like your Canon) don't have a live view - in other words, you can't "see" the image before you capture it. You must use the viewfinder.
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
LCD Doesnt Display anything
this might be a CCD image sensor problem if in shoot mode it displays only black screen, Canon will repair it for free, follow this link: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=9828&keycode=2112&id=29819
Aug 17, 2007 | Canon PowerShot A75 Digital Camera
Canon Powershot A60 Digi Cam
your problem isinternal circuit fault the recording section is not working. which is not giving any signal to LCD . you nee dto give itr in service centre. fault may also come in change over switch which is not giving connection to LCD. Sangita
Jun 22, 2007 | Canon PowerShot A75 Digital Camera
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
27 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
