Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint WD71 washer/dryer
Water gushing from powder dispenser drawer. I have been told to take out drawer and put to one side. Looking into drawer space at back on right hand side there is a hole to be unlocked. It is so scaled up I cannot see hole. Can you help me or do you have an illustration fo what I am supposed to be looking at and unblocking ? Hope you can help soon. Floor is flooding every wash and cannot afford to get man out.
  • 750 Answers
Hello farijl,
Welcome to Fixya,
You said, Water gushing from powder dispenser drawer. I have been told to take out drawer and put to one side. Looking into drawer space at back on right hand side there is a hole to be unlocked. It is so scaled up I cannot see hole. Can you help me or do you have an illustration fo what I am supposed to be looking at and unblocking ? Hope you can help soon. Floor is flooding every wash and cannot afford to get man out.
I found what you are looking for!
Below I will post the site for your WD71 User guide.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/531INST_016437770-02_WD71.pdf
If you scroll down to page 5 it will show you what and how to remove the transit brackets.
the dispenser drawer info is on pages 19 and 20.
My first post was incorrect about the bolt.
The American washers us a bolt!
Sorry.
You should be fine now and able to remedy this by your self
Let me know if you have any other questions.
Huuum
Please remember to leave a rating
Thank You
The detergent dispenser
will not close properly or is
collecting water?
1. Check the drawer is properly aligned.
2. Clean the dispenser drawer (see Care and Maintenance).
Posted on Oct 17, 2008
Dispenser still full of powder at end of cycle
Remove dispenser drawer from washer, and thoroughly clean all parts, especially the conditioner side of dispenser..
Make sure the syphon tube is clear by running water through it .
Hope this helps.
Please rate my solutoion.
Thankyou.
Jan 18, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
While washing water is leaking out of the soap drawer out of our 1st Addition Washer/Dryer Please help
Probably a soap blockage in dispenser, or washer is overfilling, or the drum is turning too fast on wash.
Check the dispenser to make sure it is clear of powder.
The drum should turn fairly slowly, or other wise it will throw water up to the diepemser if it is turning too fast.
Jan 11, 2010 | Hotpoint Washing Machines
Can this machine heat its own water? It has a hot and cold water intake. also mashing machine is not taking the powder from the powder drawer. Can you help?
Yes, this washer does have a heating element.
Make sure there is a good water pressure at the inlet valve/s,
or the powder will not dispense.
Make sure there is no blockage or obstruction in the drawer, \also make sure you have the powader in the correct compartment.
Hope this helps.
Dec 20, 2009 | Hotpoint Aquarius WD640 Front Load...
Dispenser draw filling with water, i have been told there is no filter i can clean!!? The part of the draw where you put your fabric conditioner in.
You have been ill advised, there is a filter that you can clean.
Remove rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove top cover., check the hose from dispenser to drum is not blocked with powder..
If the dispenser drawer still fills up, then it is possible that the condenser is blocked with fluff.
This a major job to put right, you would be well advised to call an engineer if this is the case.
Hope this helps.
Dec 13, 2009 | Hotpoint Aquarius WD63 Front Load...
WD 63
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD440 Drawer overflowing
Hi.
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Thanks.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
Water gush in power drawer
You have a seal that is not working right for one. and 2 you have a water pump that is not working. because it is not limiting the water supply.
Aug 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Mar 06, 2008 | Hotpoint Ultima WD72 Front Load...
Soap dispenser
Some softeners are too thick, you could dilute this with water before you add to the machine. Note: Your tube to the softener drawer could be loose or something, you could check this by taking the top of the machine off to examine. Actually simple.
Oct 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
254 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
freddyfox
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
