Question about Car Audio & Video
I installed a goodmans gce 7355 mp3 stereo into my Hiace van and it worked for ten minutes fine.Then when I unplugged it to fix to the dash securely it would not power up.After reading through the instal manual it said if this happened switch the 12v memory 2 the 12v power(ignition)which appeared to solve the stereo power problem,however now my heater will not put out hot air and the keyfob will not lock or unlock the doors
  • 61 Answers
SOURCE: Power door locks won't work
You need to have someone or yoursef check the body control module with a compatible scan tool. Thats where the problem you are having resides. It may need a software update or replacement. You can also disconnect the battery for a few minutes, that will cause the BCM to reset and may fix it.
Posted on Jan 28, 2009
  • 15 Answers
SOURCE: Power door locks dont work
hello on the door locks not working could be a couple problems open the driver side door and were the door hinges are there is a small tube with wires in there that runs from the door into the side of the kick panel inside of the car these wires are your windowns locks and more now were the door open you will have to cut tube with a razr knife so you can see if any of the wires are broken now if there is no wires broken now the power door lock actuators inside the front right-and left door could be bad or the door look swiches this is not unlikey you can check this by removing the door panel you will see a rod or cable going from the door lock down the bottom of the door
now on the key not working that sounds like the door lock rods there that hooks to the lock on the inside of the door is off or one of the plastic clips that hold the rods has broken if it is not locking or unlocking your doors it is not unlikey for both sides to be broken you will have to remove the door panels to check
Posted on Mar 02, 2009
motor1258
  • 6674 Answers
SOURCE: The power lock (driver's side sliding door) on our
Take a look at end of door where latch is & post where the 2 meet when closed. Look for round metal button/contacts, about 1/2" in diameter. If you look close, they should line up to make contact with each other when door is closed. Take some fine steel wool (preferred) or fine sandpaper and scuff them up until you see metal is clean on both surfaces. Now try it, and let me know what happens.
Posted on Mar 09, 2009
SOURCE: 2002 Dodge Grand Caravan Driver Door Lock/Unlock Switch
sorry not sure the 12v prob will help this swtich works on 5v off 3v unlock 1v lock single wire lock/unlock logic signals
I found wiring diagrams at
http://www.dodge.com/bodybuilder/2004/docs/wd/rswd/tc.pdf
it is 2004 but use the wiring diagrams to test the wires
(most likely to fail where they flex)
because it is using logic gates disconnect the plug at each end of the wire you are testing or the damn thing will find a few diffrent ways to trick you.
Posted on Apr 21, 2009
  • 412 Answers
SOURCE: 2006 Dodge Caravan - ONE power door lock stopped working
i have replaced many sliding door lock actuators on these vehicles..dealer part..mostly on passenger side sliding door..also possible you have a broken wire in door track harness..follow wiring from door into what looks like a plastic chain in door track at door opening
Posted on May 14, 2009
Odometer toyota hiace van
You need the cluster scanned to determine the cause.
Nov 06, 2013 | Cars & Trucks
2004 Alero wont start!
sound like theft security problem.when you try ten minutes did you leave ignition switch on position for ten minutes until the security light turn off then turn off ignition switch for 5 seconds then try starting vechicle.when you do 10 minute trick security light has to turn off or disappear when you see security light go off turn off switch 5 seconds then try starting vechicle.
May 22, 2013 | 2004 Oldsmobile Alero
Hiace wont start and security light is on
I am sorry but this model is not sold in the US so we have no tech data on it to give you.
May 17, 2012 | Cars & Trucks
1999 gmc savanna 3500 van, reprogram ignigtion key
place the key in the ignition and turn on.leave on for ten minutes.once ten minutes is up security light will either flash or go out.then turn off and then on again.repeat 3 times.this is a 30 minute relearn.remember just turn the key to run not start.good luck
Dec 14, 2011 | GMC Vehicle Parts & Accessories
I need a manual for Goodmans car radio modelGCE 7357MP3
http://www.cintelcorp.net/goodmans-gce-7350-mp3r-manual
download from this link.
Nov 06, 2011 | Goodmans CD / MP3 car radio GCE780MPT CD...
2005 astro security problem. Passlock? Security light came on while driving. I do not have a chip in my key. About an hour later van would not start and light was flashing. Waited ten minutes and van...
the security module does not receive the expected input (or produce the expected output for the ECM) which is why this is such a common issue. I have had success by cutting the input wire on the security module, located under the dash on the passenger side, and installing a 2200 ohm resistor-this fools the security module into thinking the lock cylinder is not being tampered with, and is cheap to do if this is your problem. If, however, it is the security module itself, there are work-arounds that involve either buying someone's fix, or instructions on building a module yourself that, for all intents and purposes, disables the system altogether. Most of the time, the resistor to the security module input works though as the ignition switch wears and the readings from it change over time. Here is a good writeup on how to do this yourself-while this is written for a Grand Am, it pretty much applies to GM's from 96 to 05 with passlock.
http://www.bergerweb.net/grandamsecurityfix.htm
Sep 01, 2011 | Chevrolet Astro Cars & Trucks
When key is turned player goes straight to cd and radio memories are lost? help please .product goodmans gce 7350mp3r
Make sure the yellow wire is going to a source that is still hot even with the key off. The yellow wire controls the memory of your deck.
Jul 11, 2011 | Goodmans CD / MP3 car radio GCE780MPT CD...
Security light on dash lit
i have this same problem. it has to do with the passlock security system that is factory installed. my system is cold weather sensitive. you go to start it and it will die. the security system then goes into stupid mode and its a 10 minute wait so the computer wont think your stealing your van ,then it will restart. sometimes it goes into another ten minutes if you try starting it to soon. security light flashing equals no start. solid security light equals ok to start. the system cuts power to the fuel pump. i live with it. it is managable but frusterating.
Jun 12, 2009 | 1999 Chevrolet Astro
Radio installation in 1983 dodge ram van
remove screws from dash face, remove dash face. two 10mm bolts hold stereo in place,remove bolts, gently pull stereo out. unplug stereo. install new stereo by reversing the directions
Oct 19, 2008 | 1983 Dodge Ram Wagon
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
