Question about Brasstech 121-10B Large Basket Strainer, Post Type-Oil Rubbed Bronze
What engine oil for mitsubishi grandis 1998
What type of oil is best suited to a mitsubishi grandis super exceed
  • 49 Answers
Manufacturers recomendations
Posted on Jan 23, 2009
WHY IS MY MITSUBISHI GRANDIS 2005 2.4L 4G69 ENGINE IS USING WAY TOO MUCH FUEL?
Check the ECT coolant sensor for sticking too low and causing way too rich of a mixture .
Aug 12, 2017 | Mitsubishi Cars & Trucks
How do I set the clock on a 2005 Mitsubishi Grandis?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Sep 06, 2016 | 2005 Mitsubishi Grandis
What kind of motor oil does a 2003Dodge Caravan SE van use.
THE 2.4L ENGINES USE 5W-30 3.3L AND 3.8L ENGINES USE 5W - 20
Oct 08, 2010 | 2003 Dodge Caravan
I have a 98 mitsibishi chariot grandis gdi, it smokes badly while warming up but then gets less while driving. The smoke is bluish white.
I think it is blue oil smoke that you are describing, indicating internal engine wear of piston rings and/or valve guides leaking excessive oil.
Usually, this occurs to high mileage vehicles, or vehicles which haven't had regular oil changes every 3,000 mi. for the life of the engine.
Aug 22, 2010 | Mitsubishi Minivan Cars & Trucks
Vehicle smoking
If your car has blue smoke, then that is oil that is burning. You might have a worn out engine or bad valves. To check the condition on your engine, you should get a engine compression check. Was your engine oil level checked for proper oil levels?
Mar 27, 2009 | 2003 Mitsubishi Outlander
Mitsubishi chariot gdi
Hi, I have a Mitsubishi Chariot Grandis Exceed 1998 (4g64) and recently changed the engine. Prior to changing the engine the car had a shudder when driving approximately 70kmph. This appears to be caused by some sort of misfire as one can see the ref counter dropping and picking up slowly. After changing the engine I still have exactly the same problem which tells me it is not the engine. I took it in and they tested it with one of those plug in machines but to no avail as it did not pick up any faults. Due to the slight drop of the needle prior to the car shuddering, I cleaned out the injectors but this does not appear to be a part of the problem. This usually occurs more often when the engine is warmer and not when one start up and drive. Any ideas what can cause this?
Aug 23, 2008 | Mitsubishi Passenger Cars & Trucks
Brasstech 121-10B Large Basket Strainer, Post Type-Oil Rubbed Bronze  Logo
654 people viewed this question
Top Brasstech Plumbing Experts
Donni Steen
Tom Chichester
Are you a Brasstech Plumbing Expert? Answer questions, earn points and help others
