Question about HP Office Equipment & Supplies
My Officejet 5610xi All-in-One will not print from my computer. The printer tells me it is not connected to my computer
  • 2 more comments
  • mkevwitch Oct 17, 2008
    I have unplugged and plugged back in all the connections and it still does not work.
    I don't understand what driver you are talking about.
    I have looked for the cd that came with my printer but I haven't found it yet.
    I used a different USB port but still did not work. Is the cd a sure fix?
  • HP Master
  • 6,487 Answers
If the new cable still didn't work , this can be a problem with teh printer itself since its not detected by your computer and the CD wont be able to fix it...
Posted on Oct 17, 2008
    Sergeant:
  • 306 Answers
It happens at times
i recommend you to uninstall ur printer
restart ur system
install the printer
restart ur system
n ur problem is solved !!
  • AbdulRahiman S Oct 17, 2008
    u reinstall it.. and chek out!! i think it may help..
    Else..
      Turn your printer on, remove the power cable at the back of your printer while the printer is ON. PRESS AND HOLD the # key and 3 key on the keypad, plug back the power cable WITHOUT releasing those buttons, DO NOT RELEASE THE BUTTONS until you can see the WELCOME SCREEN or INPROPER SHUT DOWN PRESS OK TO CONTINUE.
    Genius:
  • 1,269 Answers
You can try replacing the USB cable. If the computer tells you it is not connected, it has something to do with the physical connections. Make sure the power cable is plugged in to the printer and it is turned on. Verify if the USB cable is properly plugged in. Try different USB port on your computer. To isolate the problem, you can try to plug the printer to a different computer and see if it detects it.
    Guru:
  • 859 Answers
Are you using USB? If so, you may need to us a different USB port. However, should you feel the need to reinstall the driver set, you must have the USB cable DISCONNECTED while doing this. You will be instructed by the installer WHEN to actually attach the USB cable. This is quite important.
Do you need a link to your latest drivers?
Don't rate this until we are done, you and I, otherwise you won't see any further post I send to you. Okay?
Regards,
Worldvet
  • Glenn Rogers
    Glenn Rogers Oct 17, 2008
    Hello?
    It is important that you do things in a particular sequence otherwise you will fail and things worn't work.
    Also, when you reply, begin your reply with the board name of the expert you are replying to. Okay?
    Such as,
    Worldvet, can you repeat that?
    Thanks.
    Master:
  • 763 Answers
Try to check the cable or the usb connection from the computer to the printer it must be loosing or not connected properly to the interface. Install the the driver camed with your printer to your computer to be able to use it.
CHARCOIS
  • 4 more comments
  • Charris Suaybaguio
    Charris Suaybaguio Oct 17, 2008
    you may post if any other problems occur so that we can help you!
    thank you for using fixya
    hope that helps!
    CHARCOIS
    did you install the cd driver camed with your printer?
    sir the cd driver was with the package of your printer and its should included on the box of it. this cd driver function is to be able to use your printer to your computer. just install it and follow the wizard installation so that it will be recognizable to your computer each time you use it.
    CHARCOIS
    CHARCOIS
    here try this one. click on the mirror to download the software and after that install it on your computer. you will prompting some steps for the installation.
    http://www.techspot.com/drivers/driver/f...
    CHARCOIS
    heres another one if the above link wont work.
    http://drivers.dltube.net/install22649.h...
    just click the download mirror 1 and its should be downloading
    CHARCOIS
How do i connect my print on the computer?
Hi there
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/HP-Officejet-5600-5605-5610-5610v-5610xi-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Apr 25, 2010 | HP Officejet 5610 All-In-One InkJet...
Help! My Officejet 5610xi All in One won't print
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab66
Jun 26, 2009 | HP Officejet 5610 All-In-One InkJet...
I'm trying to get my computer to reconize my hp officejet 5610xi all in one printer and i don't have a disc for it.I can't figure out how to do it please help.i'm new to computers and don't know too much
Simply go to www.hp.com and type in Hp officejet 5610xi in the search bar and download the drivers for it. If you are still not able to search the driver call Hp support center and they will mail you the driver cd. Make sure you tell them that it was not available when you opened the box :)
Thanks
Aug 15, 2008 | HP Office Equipment & Supplies
Faded print
IT TURNED OUT TO BE A FAULTY WORN DOWN BLACK CARTRIGE!
WE REPLACED IT,AND THE PRINTER IS WORKING FINE.
THANKS,
DURANGO21
Jul 22, 2008 | HP Officejet 5610 All-In-One InkJet...
Ben Johnson
