Question about Intel Motherboard
Might Need a New Motherboard In the in a few yrs.
Well i had my computer restored to factory just a week ago and the tec. said that my motherboard had some burned out components. said it would last for awhile but would go out. it runs fast no problem yet. have 165.gb hard drive free. upgrading to 1.5 gb ram soon its a duel channel. the motherboard i have i cant find think cause its about 5 yrs old. Gigabyte GA-81PE 1000 PRO, pen 4 ,nvidia ge-force fx 5200 ultra, max ram 4gb.,2.4ghz,memory ram ddr pc 2700 ddr pc3200 up to 4 gb ddr sdram non-ecc, so my question is can i put any motherboard in my computer that is compatible with what i have here. would like to have at least the same as before or a little better maybe get up to 8 gb of ram don't think i need it but would be nice.lol if u have some motherboards sugestions plz let me know. thank you Melissa
  • Melissa64 Oct 30, 2008
    thx yeah that help me out. really don't know what i have 32 or 64 bit but i will look at the power supply and work from that might just get a new power supply as well. as for now m/board works ok but does turn on, on its own when i turn it off after about 3 hours of being off. then kicks on and off till i unplug it and restart it and kicks off again have to do this a few times before it turns on for good or off till again it turns on on its own.wierd why does that happen? other then that it works great for now think power is going out as well.might explain the kicking on and off. thanks again Melissa.
  • 781 Answers
You can put mostly any M/board in most cases the main problem will be power supply. A lot of the latest M/boards now need different power plug fittings and your power supply may not have them
(Do a careful check)
Unless you use a 64 bit operating system its useless getting that much RAM as 32 bit O/S can only use 3.35Gb of RAM
Posted on Oct 30, 2008
How do i go do a factory restore
You will need to get a Windows installation CD for the version of windows designed for your computer first.
Second you can download all your drivers for your motherboard before you format your hard drive and install windows.
http://www.msi.com/product/mb/G41M4-L.html#/?div=Driver&os=Win7%2032
May 20, 2012 | MSI G41M4-L (890552669989) Motherboard
Acer Aspire 150 - bought new 18 months ago and have been told that the motherboard has gone. Is this reasonable and has anyone else had a similar probelm and if so what did you do about it?
Is this reasonable? - no, but possible, yes. I have seen plenty of electronics go bad just a week or two past the warranty, including computers. Unfortunately, about all you can do about it is 1) get a new motherboard installed, or 2) get a new computer and this time buy the extended warranty. By the way, whoever installs your motherboard should be able to easily get your documents/files from the hard drive. You will need to reinstall Windows, and a new motherboard/processor will require a new installation. Just putting the hard drive back in will produce the "blue screen of death" just so you know ahead of time.
Oct 09, 2010 | Acer Aspire One A150-1006 Notebook
About 2-3 weeks ago mouse went couldn't use, then the key board went out about a week ago. Shut down the computer, turn comp. off from back then upluged. after check to make sure everything was still...
Impossible to diagnose remotely. You need to try things like switching the computer off at the mains for a few minutes. If I had the computer I would try a different PSU.
Oct 22, 2017 | Biostar M7VIZ Motherboard
Whenever I plug a thumbdrive I now get a bluescreen warning about XP shutting down to protect my computer and then the computer reboots. This happens whether I plug in either my Sandisk or PNY thumbdrives...
Usually blue screen errors are associated with hardware. Since you are experiencing problems after migrating the motherboard it has to do something with it.
Try removing the Jumpers and cables associated with the usb ports on your motherboard and refix them back. This will probably help you fix the problem (also make sure your jumper and cable configurations are correct - they can usually be found on *********** board manual)
If the problem still persists try taking the whole machine apart and refix it again.
Hopefully this will help you. Best Regards NextDoorNerd
Jul 28, 2010 | Intel Desktop Board D845GERG2 Motherboard
Can't access internet wireles router says connected hp is a vista
If Nothing else changed in the last 2 weeks, such as a new router, or other hardware changes, AND it just started happening, I suggest you do a "system restore" to a date BEFORE the problem started.
This should correct the problem, and if you did any updates or other software installations, you will need to re install them.
Finally, one option prior to system restoring is to turn off the wireless router (unplug it) and then wait a minute. Plug back in. Then turn on your computer. You can try this first if you haven't already..
Good luck..
Apr 23, 2010 | HP Pavilion dv6000z Notebook
I need to know how to reset a dell latitude to factory settings?
Press Ctrl + F11 While booting
The moment you see the dell logo Press the Ctrl key and start tapping the F11. If it has the restore image it will take you to the restore page. If there is not restore image it won't work
Sep 16, 2009 | Dell Latitude D531 Notebook
Want to restore my Acer aspire 4720z!
Can you make restore disks?Does your PC boot up?If if does you ma by able to make restore disks to restore it to factory settings.If you are saying the key board doesn't work.You may need a new keyboard or possibly new motherboard
Jun 01, 2009 | Acer Aspire 4720 Notebook
Toshiba satellite m35-s456 my computer lights come on but it will not boot up?
The same thing happened to me today. I think it is the power supply connection to the mother board. I had to replace the motherboard 2 yrs ago with the same symptoms. I can reboot the computer 20 times and once the laptop will boot-up OK. But most of the time the power button will come one but the screen is blank. I'm not sure if I am going to get a new laptop or just replace the motherboard...again...
Feb 01, 2009 | Toshiba Satellite M35-S456 Notebook
Intel Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
