Model # 106.52574202
SOURCE: Freezing food in Frig especially lower compartments
Kathleen, you'll have to provide an accurate model number from the inside of your fridge for us to pull up any tech data on it. Open the door and look toward the ceiling of the fridge. But, from what you describe, it sounds like a thermister problem not a thermostat problem. A thermister is a small, temperature sensitive device that communicates with the computer to tell it what temperature its' location is at any given moment. The computer then adjusts air flow dampers, defrost cycles and cooling times accordingly. There can be many thermisters in any given refrigerator model line. These are inexpensive to purchase and easy to replace, but sometimes difficult to locate. They are usually hidden behind a small plastic shell, that looks completely unobtrusive. But they are easy to recognize for they have 2 white wires going into them that are tightly bonded together. To find them, you'll have to gut the fridge (food, shelves and all) and look closely. Focus your attention toward the area of the problem, the lower shelves/crispers. You may need to pull the rear panel out to find it, but when you do replace it. (UNPLUG YOUR FRIDGE FIRST!) Hope this gives you something to go on. If not, provide your full model number so we can assist further.
SOURCE: Kenmore Elite fridg freezing everything
Faulty Thermostate, shouldn't cost much to replace. good Luck , the Yeti
SOURCE: Kenmore bottom freezer type refrigerator freezes
sounds to me like you need to replace the thermostat again,.
Testimonial: "Thanks for the tip!"
SOURCE: vegetables in vegetable bin are freezing.
Good day,
Usually a cold weather issue.
If the machine is getting light service, then that can add somewhat to the problem.
The issue here is how much the machine runs per day,or more important, how much time it's off.
When it runs less because of cool dry conditions, the freezer will run less.
As far a food freezing only on the bottom of the fresh food section,
The longer off times contribute to that. Cold air, on the off cycle drift from the freezer compartment thru the returns into the bottom of the fridge section, which can cause that problem.
This is all based on the design of the machine, which has one compressor and one fan circulating motor.
Hate to sound corny, but, if you find a house with 7 kids and a stay at home Mom, who cooks all the meals, the door openings are high enough that this problem can't occur.
it's set on produce and theres nothing blocking the duct air
