Question about Canon Pixma iP4500 InkJet Printer
Canon Pixma iP4500 error 5100
When printing the paper got jammed and came up with an error code 5100. all paper has been cleared but still doesn't print. how do i solve this problem?
  • dengelhardt Nov 24, 2008
    I have a similar problem: two new iP4500, both did printer alignment, printed a couple of nozzle patterns and one printed a couple of 8x10s, after that: Error 5100
    Did jack_02_02_0 get an answer? Solution?
  • berrance Dec 01, 2008
    same problem hear too, does anybody have a solution? my printer is still under garentee but canon expect me to take the printer to luton, im from hull and have no way of getting it to luton.
    would ressetting the printer to factory settings solve this? i would try this but i dont know howto!
  • 4,041 Answers
Hi You can Try
Another old posting
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
I tried to print something and the paper got jammed and now I have an error code 5100. What does this mean and how can I clear it? I have removed the jammed paper. please help me
the solution is to clean the strip film,look for the paper sensor is not broken or blocked
5100 means
- Carriage unit
- Timing **** film
- Logic board
- Carriage motor all this
Feb 24, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Service error 6A00
Hello thanks for using fixya.
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma iP4500 InkJet Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
See my this "Solution" same as your's & 3 people thought that it was helpful for them
I hope this solution will also helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Jan 14, 2011 | Canon Pixma iP4500 InkJet Printer
Service error 5100
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Solution 2:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Feb 22, 2010 | Canon Pixma iP4500 InkJet Printer
Service error 5100 on canon prixma mp198
Service Error 5100
Cause : Movement of the Print Head Holder is blocked.
Action "Clear the paper jam or foreign object that is preventing the Print Hed Holder from moving, cancel printing from your computer, then turn off the machine and turn it back on again.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 06, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Alarm blinking, I restrated printer, replaced ink jet and cleared printing queue but still error code comes up and won't work . error 6A00.
6A00 is AP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 12, 2009 | Canon Pixma iP4500 InkJet Printer
I received the following error message (6A00) and my printer woun't work
Hello there.
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Nov 07, 2009 | Canon Pixma iP4500 InkJet Printer
Canon mx330 Error 5100 Error 5100 Printer error has occured. Turn printer off and then on again. If this doesnt clear the error, see the users guide for more detail.
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Nov 04, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Paper jam on canon pixma mp600
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Jun 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon Pixma iP4500 InkJet Printer Logo
2,672 people viewed this question
old marine
old marine
Corne Viljoen
