Question about HP Officejet 5610 All-In-One InkJet Printer
Align page can not run and can't get it cleared out scan not working
Original problem was the copy function will not work ..... just sits there.. someone from HP said to hit # and 6... it came up as align page... printed the page required to do alignment but the second part could not scan the page and is still active no matter what I do to cancel it or reset the printer.. I have since deleted the printer and all software for it...... I disconnect the power and when i power back up the printer is still trying to accomplish the scan endless problem
  • Anonymous Oct 17, 2008
    I have the same problem just recently with my home HP printer (don't have model number I'm at work). Any solution yet, I've been pricing some new ones doesn't seem like it's worth cost of fixing.
  • rondub Oct 29, 2008
    still looking for a solution.......
    Scholar:
  • 105 Answers
Hello rondub,
You can bypass the alignment process from the setup menu.
Posted on Oct 20, 2008
  • msmaniac Dec 01, 2008
    Please make sure that the USB cable from the allineone to the computer is unplugged before scanning the Alignment page.
My printer window on the HP PSC 2175 continues to read: 'Press Enter to align cartridges' I have done this 5 or 6 times and the message will not go away. How do I fix this problem so it will print?
Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
  4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
    • If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
    • If the message keeps reappearing or other print quality problems occur, service the product.
Models with a semi-automatic print cartridge alignment Some HP products have a semi-automatic alignment process. These models do not have an additional sensor and will print two pages for the alignment process instead of one. The alignment page must be placed on the scanner glass or into the automatic document feeder (HP Officejet V series) and scanned.
  1. Disconnect the power cord, wait five seconds, and then plug it in. This reinitializes the product and forces the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the product must be serviced.
  4. Verify that the alignment page is placed correctly on the scanner glass or in the ADF (if the product has one). Place the printed side down.
  5. 5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
  6. 6. Use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. Operate the HP All-in-One to determine if there are other problems. The unit should be serviced if other error messages or problems occur or if alignment problems occur every time the ink cartridges are changed.
To bypass the ink cartridge alignment: Press and hold the Setup button, and then press Options (or Copy Options ).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 26, 2011 | HP PSC 2175 All-In-One InkJet Printer
Colored lines on a copy page
To fix the colored lines on a copy page do the below steps
  1. Disconnect the power cord, wait five seconds, and then plug it back in. This will reinitialize the unit and force the scanner to calibrate again.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the unit must be serviced.
  4. Verify that the alignment page is placed on the scanner glass or in the automatic document feeder (if equipped) correctly. Place the printed side down.
Dec 10, 2010 | HP OfficeJet k60 All-In-One InkJet Printer
PRINT NOT CLEAR PRNITER DOUBLE LETTER
Change Cartridge(keep hands of the copper contacts), close cover, hit scan button, print scan alignment page,place printed page in scanner bed,screen on computer should come up to ALIGN click it and wait. It worked for me last year.
Nov 19, 2010 | HP Officejet 5610 All-In-One InkJet...
Print function
The printer prints alignment page; after enter button.
Place the printed page in scanned glass properly.
Press the scan button and wait untill the ON light stops blinking.
Now alignment is completed.
Regards,
Riztech
Mar 02, 2010 | HP PSC 950 All-In-One InkJet Printer
Reoccuring align page error message
Hello sir; Wen you alginedthe you have to pick up the most clear letter then press resume if you don't pick up the number or letter and press resume , he message will come back again.
Aug 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Its very good at printing blank pages, tried all the fixes I found. Nothing!
It sounds like you've gone through all the normal processes to correct the problem. This indicates a problem with the refilled cartridges. The refill ink may not be up to HP specs and be clogging the nozzles. The next step is to put in OEM cartridges (not refills) and go through the cleaning and alignment process. This should clear the problem.
Let me know if this clears the problem otherwise we can try something else.
Thanks.
May 31, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Canon MF6530 copier
If your copies are clean when you scan them by opening the top and laying the original on the platen, you need to check the scanner for the ADF (automatic document feeder). It's a narrow strip of glass to the left of the scanning platen glass. Clean it with a soft cloth dampened with clear water. (Look for some type of deposit that aligns with where you see the line on the page.)
Jun 18, 2008 | Canon imageCLASS MF6530 All-In-One...
Copying using the Duplex function
Press on duplex button and scan your originals one by one on the platen mode (exposure glass). You cannot use the ADF for this function.
After every scan press the Start button.
After the last page please press the enter button as displaying in the display.
Then the copier itself can finish making duplex copies as you wanted.
Good luck and please rate me, thanks.
Nov 27, 2007 | Ricoh Aficio 1515MF All-In-One Laser...
HP Officejet 5610 All-In-One InkJet Printer Logo
175 people viewed this question
Ben Johnson
