I have installed a Techwood DV925B Digital Terrestrial Receiver but when turning on the tv to the first channel (usually BBC1) the picture and sound is badly out of synch. This corrects itself by switching to another channel and back again but it is a nuisance. Is this a flaw or can it be corrected please? Thanks John
  • Jim Stiles May 11, 2010
    What type of cable/wire is being used between the receiver and the TV? To make sure the TV isn't the culprit, do other devices like a DVD player work just fine?
Have installed a brand new Gold Plated Scart Lead (original Scart was probably defective). Incidentally this is not a Projection TV but an attempt to prolong the life of an old-fashioned Cathode Ray Tube.
Posted on Oct 20, 2008
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
How to rechannel techwood tv wtp4210 from uk to phillipines pls, help
Techwood, is made by vestel Technologies for AO
TV How To Guides
unsure if you are trying for basic terrestrial transmissions (plugged into on-board Tuner) if so follow the guide above.
if you are trying to attach a digital tuner, that should just plug into the HDMI port and should work straight away.
if you are trying something else, or the above is not working please let us know, and I will try to resolve.
Feb 01, 2016 | Televison & Video
PICTURE FREEZES EVEY FEW SECONDS
Not enough info in your Q to help you.
1) What's the source?; TV tuner (digital terrestrial, cable, satellite. Internal or external tuner/receiver box)
2) One channel - some channels - or all channels affected?
3) Just this TV, or are other TVs affected in the house too
4) Are your neighbours having the same issues?
5) What have you done so far to troubleshoot the problem yourself? (retuned, checked cables, checked signal level, realigned aerial/antenna etc)
Oct 17, 2014 | Televison & Video
Wil my tv work with out remote
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.connecting the speaker wires of an RCA TV to an amplifier: The signal that is fed to the speakers is not designed to be fed to the line-level inputs of your amplifier. You'd need some kind of conversion and I can't tell you exactly what that would be.
Get some double-screened satellite cable and fit a female TV plug to it (or a male plug with an adapter). Connect it to RF Output 2 at the rear of your Digibox. Fit a TV plug to the other end and plug it into your TV.
Temporarily disconnect the aerial feed from the Digibox aerial socket. Switch the Digibox on to get a picture on your main TV. The Sky Digibox normally sends its signal out on UHF channel 68 so go to the second TV and tune it to 68 (or tune it till it finds the Sky picture).
Now plug the aerial cable back into the Digibox. If there is now interference on the Sky picture on the second TV (or on the terrestrial channels) your Sky signal on 68 is causing interference. Press [services] 401 [select]* and set the RF output to a different UHF channel number. You need to connect it via a Scart lead on your main TV in order to see the menu.
*In the new EPG (April 2009) it's [services] 001 [select]
Try each RF output channel number in turn (21 - 69) and retune the second TV until you get clean pictures on the terrestrial channels and the Sky channel. Also check the picture from the VCR (if connected).
This is just a brief overview. If you need a real in-depth explanation you should read the "Piping TV Around the House" Ebook by satcure.
Nov 22, 2011 | AOMNI Corporation Televison & Video
Samsung LE32N7 - Analogue channels ok - Freeview set top box ok- Tv's own digital tuner stuck on one channel (BBC1) in freeze mode - and won't unfreeze. Cannot access DTV menu- does not reset on power...
This is very common to a number of Samsung models built at the same time as yours and using the same in-built Freeview receiver.
There is no fix, the built in receiver is simply incompatible with the most recent updates to Freeview (as happened to many external boxes) and cannot be modified, the only puzzle is the length of time that your receiver kept going for. If your tv has a warranty still then you may wish to see if the fault is covered.
Without a warranty, all you can do is continue to use an external Freeview receiver. They're usually better quality anyway, and are easy to replace when they go wrong or become out of date.
Sep 17, 2010 | Samsung Televison & Video
Can only tape clear pictures on DVD recorder from BBC1/BBC2 EX78E
Are you in the UK? Is the new DVD player compatible with TV in your area?
Some technical details like make and model would be helpful.
Apr 05, 2009 | Panasonic Televison & Video
Installing a receiver
plug the receiver directly to the tv first without the panasonic. set up the receiver . then add the panasonic. the panasonic probably doesnt have a digital tuner so use composite av cables (yellow, red, white) from the reciever to the player
Dec 30, 2008 | Samsung HDTV Digital Terrestrial Receiver
I have a Wharfedale Digital Freeview Receiver LPDV832B, having set this up following the instructions provided it appears I am not receiving all the freeview channels available ie BBC1, please advise.
It is very possible that you require an aerial upgrade to receiver all the digital channels available, you should check with a local aerial installer.
SUPER8
Nov 16, 2008 | Televison & Video
Televison & Video Logo
187 people viewed this question
Top Televison & Video Experts
