Question about HP PSC 1610 All-In-One InkJet Printer
Printer: Ink problem
I just replaced the color ink cartridge in the printer. It is not printing blue. I don't know what would cause something like that. The printer is about 2 years old, it is an HP PSC 1610 All-in-One. Any help would be great. Thank you.
  • 899 Answers
This is most likely the color ink cartrige , and it is clogging up
try to use the cleaning process to clean it
but you could also dab it with cd cleaning solution or INK REFILL sets have some ink cleaning solution included( if your going to do that)
Posted on Oct 17, 2008
After changing ink cartridge incoming faxes won't print. Does something have to be reset?
Some machines recognize you changed the ink cartridge and some do not. If you shut it down and restart it, this usually helps it reset.
Feb 28, 2015 | Brother Mfc-j6710dw Multifunction Printer...
When i print in color, i get blue lines every inch!!! Any idea??Thanks
Check if any of your ink cartridges are running low; this can sometimes cause something like your situation to occur. If your ink cartridges are fine, you should clean the ink heads on your printer. Most printers can do this automatically by choosing an option in print settings, do not try to clean it manually. Let me know if you need help with this. Good luck!
Jun 30, 2011 | HP LaserJet CM1312 All-In-One Printer
My hp 712c printer prints only the pink band when I run a color test. I have replaced the original cartridge. Any ideas about the cause and solution.
The cause is either:
* clogged ink-jets not allowing yellow & blue ink to move from the ink-cartridge onto the paper;
* busted electronics inside the printer, causing the ink-jets to not "spray" at all.
Use the software to try a "print-head-cleaning" cycle.
If that fails to improve things, it's time to replace the printer.
Jun 24, 2010 | HP DeskJet 712c InkJet Printer
Dell V305W printer says ink is low and it's not!
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 01, 2009 | Dell V305w All-In-One R840635AU InkJet...
Ink
  1. Buy only genuine Dell replacement cartridges. Dell states their printer cartridges cannot be refilled with ink and that only their cartridges work in the printer.
  2. Bring the cartridge carrier of the printer to the center so you can access the ink cartridges. Open the cover of the printer and the carrier slides to the center. Make sure the printer is turned on.
  3. Remove the old black ink cartridge to use the color cartridge. If you allow the old black cartridge to remain in the printer, you will get error messages that the ink is low. The printer may also keep reverting back to the black ink as the default color when printing.
  4. Open the package of the new color cartridge carefully. Remove any blue packing tape that's on the ink cartridge. Take care not to touch the gold area or you could damage the cartridge. Insert the new color cartridge into the correct slot in the printer, the right side of the cartridge carrier. The ink cartridges aren't interchangeable; they need to be placed in the correct slot.
  5. Close the cover on your printer after installing the color cartridge. Run a print test to make sure the color cartridge is installed correctly. Use the Dell Ink Management System to monitor your printer and all-in-one functions. Thanks Thiru
Jun 15, 2009 | Dell 810 All-In-One InkJet Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
The color red will not print on My Dell A940 printer.
Try find another printer(same model- says printer B)...take printer head from printer B to your printer(says printer A),use your ink cartridge and test your printing....if all color seen on paper, then the problem is your printer head, to make sure is it true or not, use printer head from printer A into printer B.see the result...
May 26, 2009 | Dell A940 All-In-One InkJet Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
