Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag stopped working,
Good Morning, I have a machine that stopped working during a cycle, there was either loss of power to the house or the street, and I think it maybe a fuse, but not sure is there anyway of testing, it will be a few days before anyone can come out to see it. Thanks
  • 1 more comment
  • vebbert Oct 17, 2008
    The machine stopped cold while spinning. the power outlet has power. Water will not fill. top loading door switch seems to be engaging okay. is there a fuse on this machine. the wiring diagram suggests it might. any help would be most appreciated; two kids in college and don't have the cash for a repair man. thanks in advance
  • Anonymous Mar 17, 2009
    I have a 2 year old Top Loading Maytag Washer. Yesterday, the "Timer, Push Pull Switch" came loose to what ever it was connected to. The machine still works...How do I put it back so I can do laundry?
  • francis rivero May 11, 2010
    hi,
    can you re-write the problem?..what do you need to test? the washing machine or the power outlet?
    tnx 4 using fixya,
    drcool
  • 958 Answers
I'm not sure if there is a fuse inside, but if you found the diagram, you can trace the power.
on a dead set, the most common problem would be the timer switch. the one that you pull and push.
check the contacts of the timer switch.
tnx again,
drcool
Posted on Oct 19, 2008
My Maytag Performa washing machine will not stop filling with water and start the next cycle
you need to unplug it from the power when it does that to see if it stops filling. That will tell you if it is a valve issue or a problem with the controller
Feb 09, 2013 | Washing Machines
Clothes Washer stopped running. I have a Maytag PAV2300AWW clothes washer that was mistaken ran with a full load on the small load setting and stopped working mid cycle. Any help with the cause and
first check the house breaker and make sure you still have power. If it does then I would unplug the machine and lean it back against the wall to look at the motor wiring harness underneath to see if it came loose or is wet.
Mar 31, 2012 | Maytag PAV2300 Top Load Washer
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
Hi, I have a Maytag Atlantis MAV9750AGW and have experienced loss of power to the machine on many occassions over the last week. Machine stops mid cycle and has no power. Machine will eventually start...
george first thing i would do is have the receptical replaced old recepticals have a tendicy to get hot and fail also go to the electrical panel and turn the breaker fully of then on older breakers tend to get stuck when they get old sometimes they dont trip but they dont supply the correct amperage either good luck
Apr 12, 2010 | Maytag Atlantis MAV9750A Top Load Washer
Tub overflowed during wash cycle
there is valve in the back of the machine where the 2 pip going to the machine if it get power even when the spin cycle is on then the controll panel is bad if it is not getting power but the water keep comming in the valve is bad also check that the pressure switch is working fine and the tube to it is clean from suds.
hop it help you any more help you need go to 911servicetoday.com :)
Dec 31, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
PF display on my maytag neptune
it stands for power failure. i would unplug the machine for 5 or 10 minutes and that should reset the micro computer.
Mar 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Nov 08, 2006 | Maytag MAV4755A Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
286 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
